Hi All,
Moved to testing the 4.4.3 docker image – working beautifully
However, minor thing I noticed the application version is still set on 4.4.1
Kind regards,
Edd
Edward Lewis PGradCert (Geostats), MGeol, MAusIMM
Capability Lead - Data Standards
p +44 (0)115 936 3385
m +44 (0)7487559371
e edlew@anonymised.com
t @GeologistEdd
w www.koalageo.rocks
w www.bgs.ac.uk
British Geological Survey | Nicker Hill | Keyworth | Nottingham NG12 5GG | UK
This looks like some broken or not applied database migrations. Check the logs when GN starts about any problems related to the database migrations. Anyway I’d recommend you to clear the browser cache and try again before doing anything else.
In case you need to apply them manually these are the SQL commands that need to be run:
https://github.com/geonetwork/core-geonetwork/blob/main/web/src/main/webapp/WEB-INF/classes/setup/sql/migrate/v442/migrate-default.sql
https://github.com/geonetwork/core-geonetwork/blob/main/web/src/main/webapp/WEB-INF/classes/setup/sql/migrate/v443/migrate-default.sql
Best regards,
Juan Luis.
Veenderweg 13
6721 WD Bennekom
The Netherlands
Tel: +31318416664
---- On Wed, 20 Mar 2024 15:41:44 +0100 Edd Lewis - BGS via GeoNetwork-devel geonetwork-devel@anonymised.comsts.sourceforge.net wrote —
Hi All,
Kind regards,
Edd
m +44 (0)7487559371
t @GeologistEdd
w www.bgs.ac.uk
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
GeoNetwork-devel mailing list
(attachments)
