[GeoNetwork-devel] after rebase from 3.0.1 to 3.0.3 csw transaction update via API does not work
we are using a forked version of geonetwork adding an own metadata schema somehow based on iso19139. the fork happened on 3.0.1 and since then we try tp keep our version up to date with the main branches (develop and 3.0.x) using git rebase.
After rebasing onto 3.0.3 updating metadata based on our schema does not work anymore. We use csw-transaction to update our datasets by updating specific properties.
After rebasing onto 3.0.3 the update routine does work for iso19139 but not for our own schema. Did there happen any changes in Geonetwork making it necessary to change our schema? could anyone point to some may be relevant commits (may be changes in iso19139 that were necessary to avoid such a behaviour as described on our schema?
Marco
Hi Marco,
2016-03-25 13:08 GMT+01:00 Marco Lechner <mlechner@anonymised.com096…>:
Probably this https://github.com/geonetwork/core-geonetwork/wiki/CSW-pluggable-outputSchema
HTH
Francois
Marco
Transform Data into Opportunity.
Accelerate data analysis in your applications with
Intel Data Analytics Acceleration Library.
Click to learn more.
http://pubads.g.doubleclick.net/gampad/clk?id=278785351&iu=/4140
GeoNetwork-devel mailing list
