Dear all, I’m trying the following
export CATALOG=http://localhost:8080/geonetwork
export CATALOGUSER=admin
export CATALOGPASS=admin
rm -f /tmp/cookie;
curl -s -c /tmp/cookie -o /dev/null -X POST “$CATALOG/srv/eng/info?type=me”;
export TOKEN=grep XSRF-TOKEN /tmp/cookie | cut -f 7;
curl -X POST -H “X-XSRF-TOKEN: $TOKEN” --user $CATALOGUSER:$CATALOGPASS -b /tmp/cookie
MUST return @authenticated = true
curl “$CATALOG/srv/fre/q?bucket=s101” -X GET -H “X-XSRF-TOKEN: $TOKEN” --user $CATALOGUSER:$CATALOGPASS -b /tmp/cookie
curl “$CATALOG/srv/api/0.1/selections/s101” -X PUT -H “X-XSRF-TOKEN: $TOKEN” --user $CATALOGUSER:$CATALOGPASS -b /tmp/cookie -H ‘Accept: application/json’ -H ‘Content-Type: application/json’
But the last request always return 0 instead of the number of records retrieved by previous search. Those requests works fine in the API page in a browser. So probably something wrong in the CURL command ?
Any suggestions ?
Thanks
Francois
Hi Francois
I have done a quick test debugging the requests, but the 1st one doesn’t add anything to the bucket (see the code in SelectionManager.updateMDResult), seem just checking if the metadata retrieved in the query is in the bucket, that explains why the 2on one returns 0.
I think should be added another call to select the metadata, no?
Jose García
On Thu, Nov 30, 2017 at 9:47 AM, Francois Prunayre <fx.prunayre@anonymised.com31…> wrote:
rm -f /tmp/cookie;
Any suggestions ?
Thanks
Francois
GeoNetwork-devel mailing list
GeoNetwork-devel@…537…sourceforge.net
Vriendelijke groeten / Kind regards,
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
T: +31 (0)318 416664
Please consider the environment before printing this email.
Hi, fixed by adding both -c and -b eg. "-c /tmp/cookie -b /tmp/cookie " to all curl requests.
Francois
2017-11-30 10:05 GMT+01:00 Jose Garcia <jose.garcia@anonymised.com>:
Hi Francois
Jose García
On Thu, Nov 30, 2017 at 9:47 AM, Francois Prunayre <fx.prunayre@anonymised.com> wrote:
rm -f /tmp/cookie;
Any suggestions ?
Thanks
Francois
GeoNetwork-devel@anonymised.comorge.net
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
