[GeoNetwork-devel] BETA ArcCatalog to GeoNetwork plugin published on SourceForge
Hello all. First, I should introduce myself as this is my first mail to the list. I’ve been working with Jeroen at FAO for the past few weeks on some tools for sharing data with GeoNetwork. I’m also working on a metadata crawler application that will look for appriate data for GeoNetwork inclusion and create appropriate metadata for MEF creation.
I’ve just published the first tool which is a ArcCatalog plugin which allows for upload of data to GeoNetwork within the ArcCatalog environment.
You can install the software from this link:
http://sourceforge.net/project/showfiles.php?group_id=85997&package_id=89219&release_id=611302
***** Please note: this is a beta release, do not use this in a ‘live’ environment ******
The plugin requires GeoNetwork v2.2 or above in order for some of the functionality to work properly. The installer includes a readme file with basic instructions on how to use tool. If you run into any issues, please let me know!
And the code is on SVN here:
http://arcmaptools.svn.sourceforge.net/viewvc/arcmaptools/trunk/arcmaptools/AC2GeoNetwork/
Amit
