[GeoNetwork-devel] BlueNet crashes with nullpointerexception
Dear friends,
I am a newbie trying to build BlueNet from the latest source code. I use
Tomcat and mySQL in my configuration. The database was created and populated
using GAST (downloaded, built and run from the GN 2.2 latest source code
trunk) which worked.
I added the path to geonetwork, intermap and geoserver in the server.xml in
the Tomcat folder as suggested by various past posts.
When I run Geonetwork, I get the following error in my geonetwork.log file.
I would appreaciate any help in this, as I am completely stuck.
2008-11-24 15:13:59,468 INFO [jeeves.engine] - === Starting system
2008-11-24 15:13:59,468 INFO [jeeves.engine] - Java version : 10.0-b23
2008-11-24 15:13:59,468 INFO [jeeves.engine] - Java vendor : Sun
Microsystems Inc.
2008-11-24 15:13:59,578 INFO [jeeves.engine] - XSLT factory :
net.sf.saxon.IdentityTransformer
2008-11-24 15:13:59,578 INFO [jeeves.engine] - Path :
F:\BN2.2\dist\web\geonetwork\/
2008-11-24 15:13:59,578 INFO [jeeves.engine] - BaseURL : geonetwork
2008-11-24 15:13:59,578 INFO [jeeves.engine] - Loading :
F:\BN2.2\dist\web\geonetwork\/WEB-INF/config.xml
2008-11-24 15:13:59,781 INFO [jeeves.engine] - Initializing general
configuration...
2008-11-24 15:13:59,796 INFO [jeeves.engine] - Initializing defaults...
2008-11-24 15:13:59,796 INFO [jeeves.engine] - Default local is :true
2008-11-24 15:13:59,796 INFO [jeeves.engine] - Initializing resources...
2008-11-24 15:13:59,796 INFO [jeeves.engine] - Adding resource : main-db
2008-11-24 15:14:00,140 INFO [jeeves.engine] - Initializing services...
2008-11-24 15:14:00,140 INFO [jeeves.engine] - Adding service :
main.home
2008-11-24 15:14:00,156 INFO [jeeves.engine] - Adding service :
main.search
main.search.embedded
main.present.embedded
main.searchform.advanced.embedded
main.searchform.simple.embedded
rating.popup
main.present
remote.show
2008-11-24 15:14:00,156 INFO [jeeves.engine] - Adding service : feedback
2008-11-24 15:14:00,156 INFO [jeeves.engine] - Adding service : links
2008-11-24 15:14:00,156 INFO [jeeves.engine] - Adding service : about
xml.region.get
feedback.insert
util.ping
util.import
user.list
2008-11-24 15:14:00,156 INFO [jeeves.engine] - Adding service : user.get
user.update
2008-11-24 15:14:00,171 INFO [jeeves.engine] - Adding service :
user.remove
user.pwedit
user.pwupdate
user.infoedit
user.infoupdate
group.list
group.get
group.update
group.remove
xml.group.update
category.list
category.get
category.update
category.remove
xml.category.update
user.login
user.logout
2008-11-24 15:14:00,171 INFO [jeeves.engine] - Adding service : admin
2008-11-24 15:14:00,171 INFO [jeeves.engine] - Adding service : config
xml.config.get
xml.config.set
localization
xml.operation.update
xml.region.update
2008-11-24 15:14:00,171 INFO [jeeves.engine] - Adding service : help
xml.schema.info
2008-11-24 15:14:00,187 INFO [jeeves.engine] - Adding service :
file.disclaimer
file.download
graphover.show
resources.get
resources.upload
resources.del
xml.user.login
xml.user.logout
xml.search
xml.metadata.get
2008-11-24 15:14:00,187 INFO [jeeves.engine] - Adding service : xml.info
xml.forward
xml.user.list
xml.group.list
xml.metadata.insert
xml.metadata.delete
2008-11-24 15:14:00,187 INFO [jeeves.engine] - Adding service : csw
2008-11-24 15:14:00,187 INFO [jeeves.engine] - Adding service : oaipmh
rss.latest
2008-11-24 15:14:00,203 INFO [jeeves.engine] - Adding service :
rss.search
rss.present
google.kml
mef.import
mef.export
xml.relation.get
xml.relation.insert
xml.relation.delete
keywords.getselected
keywords.sort
keywords.select
keywords.search
xml.search.keywords
xml.search.keywordlink
keywords.editsearch
thesaurus.admin
thesaurus.upload
thesaurus.download
thesaurus.delete
thesaurus.view
thesaurus.add
thesaurus.edit
thesaurus.update
thesaurus.editelement
thesaurus.addelement
thesaurus.updateelement
thesaurus.deleteelement
2008-11-24 15:14:00,203 INFO [jeeves.engine] - Initializing schedules...
2008-11-24 15:14:00,203 INFO [jeeves.engine] - Loading :
F:\BN2.2\dist\web\geonetwork\/WEB-INF/config-metadata.xml
2008-11-24 15:14:00,234 INFO [jeeves.engine] - Initializing services...
2008-11-24 15:14:00,234 INFO [jeeves.engine] - Adding service :
metadata.insert.paste
metadata.insert
metadata.show
metadata.show.embedded
metadata.edit
metadata.elem.add
metadata.elem.delete
metadata.update
metadata.update.finish
metadata.update.forget
metadata.update.forgetandfinish
metadata.validate
2008-11-24 15:14:00,250 INFO [jeeves.engine] - Adding service :
metadata.elem.down
metadata.elem.up
metadata.attr.add
metadata.attr.delete
metadata.delete
metadata.recent.additions.embedded
metadata.massive.delete
metadata.massive.newowner
metadata.massive.newowner.form
metadata.massive.category.form
metadata.massive.update.categories
metadata.massive.admin.form
metadata.massive.update.privileges
metadata.select
metadata.create.form
metadata.duplicate.form
metadata.create
metadata.create.edit
metadata.admin.form
metadata.admin
metadata.category.form
metadata.category
metadata.xmlinsert.form
metadata.batchimport.form
metadata.searchunused.form
metadata.creativecommons.form
2008-11-24 15:14:00,265 INFO [jeeves.engine] - Adding service :
metadata.creativecommons.set
metadata.thumbnail.form
metadata.thumbnail.set
metadata.thumbnail.unset
transfer.ownership
xml.ownership.editors
xml.ownership.groups
xml.ownership.transfer
xml.metadata.rate
2008-11-24 15:14:00,265 INFO [jeeves.engine] - Loading :
F:\BN2.2\dist\web\geonetwork\/WEB-INF/config-harvesting.xml
2008-11-24 15:14:00,265 INFO [jeeves.engine] - Initializing services...
harvesting
xml.harvesting.get
xml.harvesting.add
xml.harvesting.update
xml.harvesting.remove
xml.harvesting.start
xml.harvesting.stop
xml.harvesting.run
xml.harvesting.info
2008-11-24 15:14:00,281 INFO [jeeves.engine] - Loading :
F:\BN2.2\dist\web\geonetwork\/WEB-INF/config-portal.xml
2008-11-24 15:14:00,281 INFO [jeeves.engine] - Initializing services...
2008-11-24 15:14:00,281 INFO [jeeves.engine] - Adding service :
portal.search
portal.opensearch
portal.search.keywords
portal.present
portal.search.present
portal.get
portal.full
portal.latest.updated
portal.featured
portal.categories
portal.sources
pdf.search
F:\BN2.2\dist\web\geonetwork\/WEB-INF/config-export.xml
2008-11-24 15:14:00,281 INFO [jeeves.engine] - Adding service : dc.xml
2008-11-24 15:14:00,281 INFO [jeeves.engine] - Adding service : fgdc.xml
iso19115to19139.xml
iso19139.xml
iso_arccatalog8.xml
anzMeta_v2toProfile.xml
19115-MCPto19139.xml
F:\BN2.2\dist\web\geonetwork\/WEB-INF/config-test.xml
test.i18n
test.i18n.xml
2008-11-24 15:14:00,281 INFO [jeeves.engine] - Initializing profiles...
2008-11-24 15:14:00,296 INFO [jeeves.engine] - Found handler :
org.fao.geonet.Geonetwork
2008-11-24 15:14:00,296 INFO [jeeves.engine] - --- Starting handler
2008-11-24 15:14:00,296 INFO [jeeves.apphand] - Initializing geonetwork...
2008-11-24 15:14:00,296 INFO [jeeves.apphand] - - Setting manager...
2008-11-24 15:14:00,312 INFO [jeeves.apphand] - - Thesaurus...
2008-11-24 15:14:00,328 DEBUG [geonetwork.thesaurus-man] - Adding thesaurus
: external.place.regions
2008-11-24 15:14:00,500 INFO [jeeves.apphand] - - Z39.50...
2008-11-24 15:14:00,515 INFO [jeeves.apphand] - Enabled. Schema
mappings is : schema-mappings.xml
2008-11-24 15:14:00,546 INFO [jeeves.apphand] - - Search...
2008-11-24 15:14:00,546 ERROR [jeeves.engine] - Raised exception while
starting appl handler. Skipped.
2008-11-24 15:14:00,546 ERROR [jeeves.engine] - Handler :
2008-11-24 15:14:00,546 ERROR [jeeves.engine] - Exception :
java.lang.Exception: directory null not found
2008-11-24 15:14:00,546 ERROR [jeeves.engine] - Message : directory
null not found
2008-11-24 15:14:00,546 ERROR [jeeves.engine] - Stack :
  at org.fao.geonet.kernel.search.SearchManager.<init>(SearchManager.java:87)
  at org.fao.geonet.Geonetwork.start(Geonetwork.java:135)
  at jeeves.server.JeevesEngine.initAppHandler(JeevesEngine.java:426)
  at jeeves.server.JeevesEngine.init(JeevesEngine.java:146)
  at jeeves.server.sources.http.JeevesServlet.init(JeevesServlet.java:66)
  at javax.servlet.GenericServlet.init(GenericServlet.java:212)
  at
org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper.java:1172)
  at org.apache.catalina.core.StandardWrapper.load(StandardWrapper.java:992)
  at
org.apache.catalina.core.StandardContext.loadOnStartup(StandardContext.java:4058)
  at
org.apache.catalina.core.StandardContext.start(StandardContext.java:4371)
  at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1045)
  at org.apache.catalina.core.StandardHost.start(StandardHost.java:719)
  at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:443)
  at org.apache.catalina.core.StandardService.start(StandardService.java:516)
  at org.apache.catalina.core.StandardServer.start(StandardServer.java:710)
  at org.apache.catalina.startup.Catalina.start(Catalina.java:578)
  at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
  at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
  at java.lang.reflect.Method.invoke(Unknown Source)
  at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:288)
  at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:413)
2008-11-24 15:14:00,546 INFO [jeeves.engine] - Starting schedule manager...
2008-11-24 15:14:00,546 INFO [jeeves.engine] - Memory used is : 3407 Kb
2008-11-24 15:14:00,546 INFO [jeeves.engine] - Total memory is : 65088 Kb
2008-11-24 15:14:00,546 INFO [jeeves.engine] - Startup time is : 1 (secs)
2008-11-24 15:14:00,546 INFO [jeeves.engine] - === System working
2008-11-24 15:14:02,343 INFO [jeeves.request] -
2008-11-24 15:14:02,359 INFO [jeeves.request] - HTML Request (from
127.0.0.1) : /geonetwork/srv/en/main.search.embedded
2008-11-24 15:14:02,359 DEBUG [jeeves.request] - Method : GET
2008-11-24 15:14:02,359 DEBUG [jeeves.request] - Content type : null
2008-11-24 15:14:02,359 DEBUG [jeeves.request] - Accept :
text/javascript, text/html, application/xml, text/xml, */*
2008-11-24 15:14:02,359 DEBUG [jeeves.request] - Session created for client
: 127.0.0.1
2008-11-24 15:14:02,375 INFO [jeeves.service] - Dispatching :
2008-11-24 15:14:02,375 DEBUG [jeeves.service] - -> parameters are :
<request>
  <download>off</download>
  <output>full</output>
  <paper>off</paper>
  <dynamic>off</dynamic>
  <similarity>1</similarity>
  <any />
  <digital>off</digital>
  <sortBy>relevance</sortBy>
  <hitsPerPage>10</hitsPerPage>
</request>
2008-11-24 15:14:02,375 INFO [jeeves.request] -
2008-11-24 15:14:02,375 INFO [jeeves.request] - HTML Request (from
127.0.0.1) : /geonetwork/srv/en/main.home
2008-11-24 15:14:02,375 DEBUG [jeeves.request] - Method : GET
2008-11-24 15:14:02,375 DEBUG [jeeves.request] - Content type : null
2008-11-24 15:14:02,375 DEBUG [jeeves.request] - Accept :
text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
2008-11-24 15:14:02,375 INFO [jeeves.service] - Dispatching : main.home
2008-11-24 15:14:02,390 DEBUG [jeeves.service] - -> no input parameters
2008-11-24 15:14:02,390 INFO [jeeves.service] - -> dispatching to output
for : main.home
2008-11-24 15:14:02,390 ERROR [jeeves.service] - Exception when executing
service
2008-11-24 15:14:02,390 ERROR [jeeves.service] - (C) Exc :
java.lang.NullPointerException
2008-11-24 15:14:02,390 DEBUG [jeeves.service] - Raised exception while
executing service
<error id="error">
  <message />
  <class>NullPointerException</class>
  <stack>
    <at class="org.fao.geonet.services.main.Search" file="Search.java"
line="69" method="exec" />
    <at class="jeeves.server.dispatchers.ServiceInfo"
file="ServiceInfo.java" line="238" method="execService" />
file="ServiceInfo.java" line="141" method="execServices" />
    <at class="jeeves.server.dispatchers.ServiceManager"
file="ServiceManager.java" line="377" method="dispatch" />
    <at class="jeeves.server.JeevesEngine" file="JeevesEngine.java"
line="621" method="dispatch" />
    <at class="jeeves.server.sources.http.JeevesServlet"
file="JeevesServlet.java" line="173" method="execute" />
file="JeevesServlet.java" line="89" method="doGet" />
    <at class="javax.servlet.http.HttpServlet" file="HttpServlet.java"
line="617" method="service" />
line="717" method="service" />
    <at class="org.apache.catalina.core.ApplicationFilterChain"
file="ApplicationFilterChain.java" line="290" method="internalDoFilter" />
  </stack>
  <request>
    <language>en</language>
    <service>main.search.embedded</service>
  </request>
</error>
2008-11-24 15:14:02,390 INFO [jeeves.service] - -> dispatching to error
for : main.search.embedded
2008-11-24 15:14:02,593 ERROR [jeeves.service] - Exception executing gui
service : java.lang.NullPointerException
2008-11-24 15:14:02,609 ERROR [jeeves.service] - (C) Stack trace is :
  at org.fao.geonet.guiservices.util.Env.exec(Env.java:53)
  at jeeves.server.dispatchers.guiservices.Call.exec(Call.java:75)
  at
jeeves.server.dispatchers.AbstractPage.invokeGuiService(AbstractPage.java:119)
  at
jeeves.server.dispatchers.AbstractPage.invokeGuiServices(AbstractPage.java:103)
  at
jeeves.server.dispatchers.ServiceManager.dispatchOutput(ServiceManager.java:640)
  at
jeeves.server.dispatchers.ServiceManager.dispatch(ServiceManager.java:383)
  at jeeves.server.JeevesEngine.dispatch(JeevesEngine.java:621)
  at jeeves.server.sources.http.JeevesServlet.execute(JeevesServlet.java:173)
  at jeeves.server.sources.http.JeevesServlet.doGet(JeevesServlet.java:89)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
  at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
  at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
  at com.jspbook.GZIPFilter.doFilter(GZIPFilter.java:69)
  at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
  at
  at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
  at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
  at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
  at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
  at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
  at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:286)
  at
org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:845)
  at
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583)
  at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
  at java.lang.Thread.run(Unknown Source)
2008-11-24 15:14:02,609 INFO [jeeves.webapp.main.home] - Returning search
data
2008-11-24 15:14:02,609 ERROR [jeeves.service] - Exception executing gui
  at org.fao.geonet.guiservices.keywords.Get.exec(Get.java:55)
  at
  at
jeeves.server.dispatchers.AbstractPage.invokeGuiServices(AbstractPage.java:104)
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
jeeves.server.dispatchers.ServiceManager.dispatchError(ServiceManager.java:724)
  at
jeeves.server.dispatchers.ServiceManager.handleError(ServiceManager.java:465)
  at
jeeves.server.dispatchers.ServiceManager.dispatch(ServiceManager.java:410)
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
2008-11-24 15:14:02,609 INFO [jeeves.service] - -> transforming with
stylesheet : F:\BN2.2\dist\web\geonetwork\/xsl/error.xsl
2008-11-24 15:14:02,875 ERROR [jeeves.service] - Exception executing gui
2008-11-24 15:14:02,875 ERROR [jeeves.service] - (C) Stack trace is :
  at org.fao.geonet.guiservices.util.Sources.exec(Sources.java:50)
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
2008-11-24 15:14:02,890 ERROR [jeeves.service] - (C) Stack trace is :
  at
org.fao.geonet.guiservices.metadata.GetLatestUpdated.exec(GetLatestUpdated.java:76)
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
2008-11-24 15:14:02,890 ERROR [jeeves.service] - Exception executing gui
  at org.fao.geonet.guiservices.metadata.GetRandom.exec(GetRandom.java:82)
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
2008-11-24 15:14:02,890 INFO [jeeves.service] - -> transforming with
stylesheet : F:\BN2.2\dist\web\geonetwork\/xsl/main-page.xsl
2008-11-24 15:14:03,562 INFO [jeeves.service] - -> end error
transformation for : main.search.embedded
2008-11-24 15:14:03,562 INFO [jeeves.service] - -> error ended for :
2008-11-24 15:14:04,156 INFO [jeeves.service] - -> end transformation
for : main.home
2008-11-24 15:14:04,156 INFO [jeeves.service] - -> output ended for :
main.home
2008-11-24 15:14:04,156 INFO [jeeves.service] - -> dispatch ended for :
main.home
2008-11-24 15:14:12,281 INFO [jeeves.request] -
2008-11-24 15:14:12,281 INFO [jeeves.request] - HTML Request (from
2008-11-24 15:14:12,281 DEBUG [jeeves.request] - Method : GET
2008-11-24 15:14:12,281 DEBUG [jeeves.request] - Content type : null
2008-11-24 15:14:12,281 DEBUG [jeeves.request] - Accept :
2008-11-24 15:14:12,281 INFO [jeeves.service] - Dispatching : main.home
2008-11-24 15:14:12,281 DEBUG [jeeves.service] - -> no input parameters
2008-11-24 15:14:12,281 INFO [jeeves.service] - -> dispatching to output
for : main.home
2008-11-24 15:14:12,375 ERROR [jeeves.service] - Exception executing gui
2008-11-24 15:14:12,375 ERROR [jeeves.service] - (C) Stack trace is :
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
2008-11-24 15:14:12,390 INFO [jeeves.webapp.main.home] - Returning search
data
2008-11-24 15:14:12,390 ERROR [jeeves.service] - Exception executing gui
2008-11-24 15:14:12,390 ERROR [jeeves.service] - (C) Stack trace is :
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
2008-11-24 15:14:12,421 ERROR [jeeves.service] - Exception executing gui
2008-11-24 15:14:12,421 ERROR [jeeves.service] - (C) Stack trace is :
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
2008-11-24 15:14:12,437 INFO [jeeves.service] - -> transforming with
2008-11-24 15:14:12,500 INFO [jeeves.service] - -> end transformation
for : main.home
2008-11-24 15:14:12,500 INFO [jeeves.service] - -> output ended for :
main.home
2008-11-24 15:14:12,500 INFO [jeeves.service] - -> dispatch ended for :
main.home
View this message in context: http://www.nabble.com/BlueNet-crashes-with-nullpointerexception-tp20654729p20654729.html
Sent from the geonetwork-devel mailing list archive at Nabble.com.
Hi Harry,
Rather unusual install process you've used there? - you should be able to use the gast tool with the BlueNet MEST (if thats what you need).
The crash you've got is not a nullpointerexception, its actually trying to tell you that the htmlCacheDir (see the setting in web/geonetwork/WEB-INF/config.xml) doesn't exist (but its printing null for the name of that directory due to a small bug in the error message). I've fixed the error message (its in the commit tonight) but you'll need to check and fix the setting of htmlCacheDir in your web/geonetwork/WEB-INF/config.xml file.
Also, I'd advise using the BlueNet MEST for everything or the GN 2.2 trunk for everything - don't mix them as there are still some differences as to where certain files are kept etc etc.
At this stage you should only be using the BlueNet MEST if you need the ANZLIC (Australian metadata profile) or some other feature in it that is not yet committed to the trunk - you're welcome to use it - but remember it is a sandbox project, not the trunk.
Simon
HarryLim wrote:
Dear friends,
Microsystems Inc.
configuration...
main.home
main.search
rating.popup
main.present
remote.show
xml.region.get
feedback.insert
util.ping
util.import
user.list
user.update
user.remove
user.pwedit
user.pwupdate
user.infoedit
user.infoupdate
group.list
group.get
group.update
group.remove
xml.group.update
category.list
category.get
category.update
category.remove
xml.category.update
user.login
user.logout
xml.config.get
xml.config.set
localization
xml.region.update
xml.schema.info
file.disclaimer
file.download
graphover.show
resources.get
resources.upload
resources.del
xml.user.login
xml.user.logout
xml.search
xml.metadata.get
xml.forward
xml.user.list
xml.group.list
xml.metadata.insert
xml.metadata.delete
rss.latest
rss.search
rss.present
google.kml
mef.import
mef.export
xml.relation.get
xml.relation.insert
xml.relation.delete
keywords.sort
keywords.select
keywords.search
xml.search.keywords
keywords.editsearch
thesaurus.admin
thesaurus.upload
thesaurus.download
thesaurus.delete
thesaurus.view
thesaurus.add
thesaurus.edit
thesaurus.update
metadata.insert
metadata.show
metadata.edit
metadata.elem.add
metadata.update
metadata.validate
metadata.elem.down
metadata.elem.up
metadata.attr.add
metadata.delete
metadata.select
metadata.create
metadata.admin.form
metadata.admin
metadata.category
transfer.ownership
xml.metadata.rate
harvesting
xml.harvesting.get
xml.harvesting.add
xml.harvesting.stop
xml.harvesting.run
xml.harvesting.info
portal.search
portal.opensearch
portal.present
portal.get
portal.full
portal.featured
portal.categories
portal.sources
pdf.search
iso19115to19139.xml
iso19139.xml
iso_arccatalog8.xml
test.i18n
test.i18n.xml
null not found
  at
  at
  at
: 127.0.0.1
2008-11-24 15:14:02,375 DEBUG [jeeves.service] - -> parameters are : <request>
  <paper>off</paper>
  <any />
</request>
for : main.home
service
executing service
<error id="error">
  <message />
  <stack>
  </stack>
  <request>
  </request>
</error>
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
data
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
for : main.home
main.home
main.home
for : main.home
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
data
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
for : main.home
main.home
main.home
Simon Pigot wrote:
Hi Harry,
Hmm, yes, there is a nullpointerexception later on in the log file :slight_smile: But the actual cause is the first exception raised when the htmlCacheDir is not found as discussed below.
Begins in your log file with:
See the rest of my response below.
Simon
Simon
HarryLim wrote:
Dear friends,
Microsystems Inc.
configuration...
main.home
main.search
rating.popup
main.present
remote.show
xml.region.get
feedback.insert
util.ping
util.import
user.list
user.update
user.remove
user.pwedit
user.pwupdate
user.infoedit
user.infoupdate
group.list
group.get
group.update
group.remove
xml.group.update
category.list
category.get
category.update
category.remove
xml.category.update
user.login
user.logout
xml.config.get
xml.config.set
localization
xml.region.update
xml.schema.info
file.disclaimer
file.download
graphover.show
resources.get
resources.upload
resources.del
xml.user.login
xml.user.logout
xml.search
xml.metadata.get
xml.forward
xml.user.list
xml.group.list
xml.metadata.insert
xml.metadata.delete
rss.latest
rss.search
rss.present
google.kml
mef.import
mef.export
xml.relation.get
xml.relation.insert
xml.relation.delete
keywords.sort
keywords.select
keywords.search
xml.search.keywords
keywords.editsearch
thesaurus.admin
thesaurus.upload
thesaurus.download
thesaurus.delete
thesaurus.view
thesaurus.add
thesaurus.edit
thesaurus.update
metadata.insert
metadata.show
metadata.edit
metadata.elem.add
metadata.update
metadata.validate
metadata.elem.down
metadata.elem.up
metadata.attr.add
metadata.delete
metadata.select
metadata.create
metadata.admin.form
metadata.admin
metadata.category
transfer.ownership
xml.metadata.rate
harvesting
xml.harvesting.get
xml.harvesting.add
xml.harvesting.stop
xml.harvesting.run
xml.harvesting.info
portal.search
portal.opensearch
portal.present
portal.get
portal.full
portal.featured
portal.categories
portal.sources
pdf.search
iso19115to19139.xml
iso19139.xml
iso_arccatalog8.xml
test.i18n
test.i18n.xml
null not found
  at
  at
  at
: 127.0.0.1
  <paper>off</paper>
  <any />
</request>
for : main.home
service
executing service
<error id="error">
  <message />
  <stack>
  </stack>
  <request>
  </request>
</error>
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
data
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
for : main.home
main.home
main.home
for : main.home
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
data
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
for : main.home
main.home
main.home
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
GeoNetwork-devel mailing list
geonetwork-devel List Signup and Options
GeoNetwork OpenSource is maintained at GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
