These last few days Francois and I have been reviewing / merging the open pull requests, not all, but quite quite a few reviewed / merged. Also the branches are reorganised like this:
main branch, based on previous 4.0.x.
3.12.x branch, based on previous master.
For now no specific branch for 4.0.x (main branch is used for 4.0.x releases). After the release of 4.0.4 in 1/ 2 weeks will be created the branch 4.0.x and main will be set up for the future 4.2 version.
Pull requests should be addressed to the main branch, unless specific for 3.x versions.
If you have checked out the code you’ll need to update locally to point to the new branches.
