[GeoNetwork-devel] Bug on install with Java 1.6 (heikki)
when you install GN, you can change the installing path to no space (" ") included in , it will be ok.
c:\program files\gn —> c:\profiles\gn
Hi Jeroen,
I have XP and JRE 1.6, and have never experienced any problem. Do you have more specifics on the circumstances where this problem occurs?
My version of Java is :
C:>java -version
java version “1.6.0_03”
Java™ SE Runtime Environment (build 1.6.0_03-b05)
Java HotSpot™ Client VM (build 1.6.0_03-b05, mixed mode, sharing)
and I’m regularly installing GeoNetwork, both versions 2.1 and 2.2, always choosing to import sample metadata.
Kind regards
Heikki Doeleman
雅虎邮箱传递新年祝福,个性贺卡送亲朋!
