[GeoNetwork-devel] build update - The following untracked working tree files would be overwritten by merge
One of the changes introduced during the sprint was including the contents of iso19115-3.2018 directly in master (rather than as a submodule).
If you update with git pull you will get the following error:
From github.com:geonetwork/core-geonetwork
* branch master → FETCH_HEAD
= [up to date] master → upstream/master
error: The following untracked working tree files would be overwritten by merge:
schemas/iso19115-3.2018/ISO19115-3-2014-to-ISO19115-3-2018.xsl
schemas/iso19115-3.2018/ISO19139-to-ISO19115-3-2018.xsl
Here is how to update:
cd schemas
rm -r iso19115-3.2018
git pull
git checkout .
For more information:
Jody Garnett
Thanks Jody for the update.
Also note that a couple of projects are still using metadata101 so don’t be surprised that on my side some fixes will be applied to metadata101 and synch master from time to time - not sure what is best for this as we can’t cherry-pick probably.
I’ll try to do the move for 4.0.x branch soon.
At some point, we will have to archive the project on metadata101.
Francois
Le mar. 11 août 2020 à 07:26, Jody Garnett <jody.garnett@anonymised.com> a écrit :
cd schemas
git pull
git checkout .
Jody Garnett
Jody Garnett
GeoNetwork-devel mailing list
