[GeoNetwork-devel] Change template top-toolbar.html to customized header
Does the war file contains the wro4j cache?
How are you activating your view? Parameter or via settings?
On Mon, Apr 25, 2016 at 11:17 AM, gabi9001@anonymised.com
<gabi9001@anonymised.com> wrote:
I found, that if I create a new file into the folder /catalog/templates/
where the original top-toolbar.html is the ng-include works. It stopps
working if I try to reference to any html inside my own view folder.
Gabi
-------- Ursprüngliche Nachricht --------
Von: gabi9001@anonymised.com
Datum:25.04.2016 11:07 (GMT+01:00)
An: María Arias de Reyna
Betreff: AW: Re: [GeoNetwork-devel] Change template top-toolbar.html to
customized header
Hi Maria,
thank's for your reply.
I work with the war file on Lubuntu 15.
I tried to create my own view, leaving default as fallback position.
I started quite simple following the documentation 'create your own view'
and just have an index.html and very rudimentary module. If I put a
'ng-include' command in the index I end up with parts of the topbar.
After every change I empty the cache and restart tomcat.
No, debug does not work.
Mmh, I just noticed that it is perhaps not specifically the topbar. In the
response there is definitely included the signin.html, overwriting the
content of my template.
Do you need more information?
Thank you for your help!
Gabi
