This was a command line build, not Eclipse. "svn co ..." followed by
"mvn package". How odd.
My settings are:
$ mvn -version
Apache Maven 2.2.1 (r801777; 2009-08-06 20:16:01+0100)
Java version: 1.6.0_15
Java home: C:\Program Files\Java\jdk1.6.0_15\jre
Default locale: en_GB, platform encoding: Cp1252
OS name: "windows xp" version: "5.1" arch: "x86" Family: "windows"
Oh well, I'm up and running with InputStreamBridge in its own file for
now. Never mind.
J.
Sent: 14 December 2010 12:05
To: Justin Rowles (C)
Cc: geonetwork-devel@lists.sourceforge.net
Subject: Re: [GeoNetwork-devel] Clean trunk not building with Java 1.6?
hi Justin,
I have no problem doing "mvn package" on a clean trunk with Java 1.6. My
version is
java version "1.6.0_22"
Java(TM) SE Runtime Environment (build 1.6.0_22-b04)
Java HotSpot(TM) Client VM (build 17.1-b03, mixed mode, sharing)
Running on Windows 7.
Did you try building on the command line, to see if there is not any
Eclipse-related problem ?
Kind regards
Heikki Doeleman
On Tue, Dec 14, 2010 at 11:11 AM, Justin Rowles (C)
<Justin.Rowles@anonymised.com> wrote:
I've just started rebuilding my workspace after a tragic Eclipse based
incident, and I can't get the clean trunk to build with 'mvn package'. I
am using JDK 1.6.02.
Specifically, I get:
[ERROR] BUILD FAILURE
[INFO]
[INFO] Compilation failure
C:\jrowles_Inspire_2_5_0_view\inspire\src\GeoNetworkWorkspace\GeoNetwork
MavenEclipse2\trunk\web\src\main\java\org\fao\geonet\kernel\mef\MEFVisit
or.java:[59,2] cannot find symbol
symbol : class InputStreamBridge
or.java:[59,30] cannot find symbol
or.java:[101,2] cannot find symbol
or.java:[101,30] cannot find symbol
InputStreamBridge is declared in IVisitor.java (not sure why) . If I
move it out to its own file, I can build fine.
Anyone know anything about scope changes in Java 1.6? It may mean that
this change needs to be committed to trunk.
Justin.
This email is only intended for the person to whom it is addressed and
may contain confidential information. If you have received this email in
error, please notify the sender and delete this email which must not be
copied, distributed or disclosed to any other person.
Unless stated otherwise, the contents of this email are personal to the
writer and do not represent the official view of Ordnance Survey. Nor
can any contract be formed on Ordnance Survey's behalf via email. We
reserve the right to monitor emails and attachments without prior
notice.
Thank you for your cooperation.
Ordnance Survey
Romsey Road
Southampton SO16 4GU
Tel: 08456 050505
http://www.ordnancesurvey.co.uk
Lotusphere 2011
Register now for Lotusphere 2011 and learn how
to connect the dots, take your collaborative environment
to the next level, and enter the era of Social Business.
http://p.sf.net/sfu/lotusphere-d2d
GeoNetwork-devel mailing list
This email is only intended for the person to whom it is addressed and may contain confidential information. If you have received this email in error, please notify the sender and delete this email which must not be copied, distributed or disclosed to any other person.
Unless stated otherwise, the contents of this email are personal to the writer and do not represent the official view of Ordnance Survey. Nor can any contract be formed on Ordnance Survey's behalf via email. We reserve the right to monitor emails and attachments without prior notice.
Ordnance Survey
Romsey Road
Tel: 08456 050505
