[GeoNetwork-devel] Codelist in custom schema
Hello everyone,
How do I get my schema to consume its own codelist. Currently it is
consuming the iso19139 codelist ...
Sent from: http://osgeo-org.1560.x6.nabble.com/GeoNetwork-developer-f3874395.html
Hi
There’s a bug in iso19139 template:
https://github.com/geonetwork/core-geonetwork/blob/master/schemas/iso19139/src/main/plugin/iso19139/layout/layout.xsl#L449
That line should be using $codelists instead of $iso19139codelists:
<xsl:param name=“codelists” select=“$codelists” required=“no”/>
There’s an open issue, will make a pull request so gets fixed in next version, for now you can update your setup.
Jose García
Vriendelijke groeten / Kind regards,
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
T: +31 (0)318 416664
Please consider the environment before printing this email.
Hi
Here are the pull requests for 3.6.x and master branches to fix this issue:
https://github.com/geonetwork/core-geonetwork/pull/3603
https://github.com/geonetwork/core-geonetwork/pull/3602
Jose García
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
Thank you Jose,
It worked!
