I started working (through Jeroen T.) on the GN-project for Swiss Topo:
http://www.nabble.com/Announcement-SwissTopo-developments-for-GeoNetwork-td20683715.html
You can find some info on my other projects on http://www.justobjects.nl
My current task is to develop a Harvester for the Catalog Gateway Protocol (CGP) see also http://www.geocat.ch. I've also started developing a generic JUnit/XMLUnit-based tester for declarative (XML) in-JVM testing of Jeeves services that may be useful for testing other GN-services.
I have read, understood, and agree to the committer responsibilities and guidelines documented at http://trac.osgeo.org/geonetwork/wiki/committer.
May I be granted access as a committer to the geocat sandbox area ?
My SF username is justb
thanks,
--Just
Just van den Broecke just@anonymised.com
Just Objects B.V. tel +31 65 4268627 Skype: justb4
The Netherlands http://www.justobjects.nl
Hi Just,
You've been added as a committer for the sandbox geocat.ch. Welcome on board!
Although you can commit to Trunk also (due to the limited configuration options administrators on sourceforge have to configure fine grained access control on SVN) you are obviously requested not to do so
. I just mention this to ensure you (as well as other sandbox committers) know this in order to avoid unintentional errors.
Ciao,
Jeroen
On Feb 5, 2009, at 10:21 AM, Just van den Broecke wrote:
GN-services.
guidelines documented at committer – GeoNetwork opensource Developer website.
thanks,
--Just
Create and Deploy Rich Internet Apps outside the browser with Adobe(R)AIR(TM)
software. With Adobe AIR, Ajax developers can use existing skills and code to
build responsive, highly engaging applications that combine the power of local
resources and data with the reach of the web. Download the Adobe AIR SDK and
Ajax docs to start building applications today-http://p.sf.net/sfu/adobe-com
GeoNetwork-devel mailing list
