I had forgotten these steps (submodule).
Thanks a lot.
But this error persists in web-ui-docs...
Is there a link between Homepage problems and web-ui-docs module ?
[INFO] --- frontend-maven-plugin:0.0.23:npm (npm download modules) @ web-ui-docs ---
[INFO] Running 'npm install --color=false' in /.../core-geonetwork/web-ui-docs
[ERROR] npm WARN package.json geonetwork-docs@...1126... No repository field.
[ERROR] npm http GET https://registry.npmjs.org/grunt
[ERROR] npm http 304 https://registry.npmjs.org/grunt-ngdocs
[ERROR] Failed to execute goal com.github.eirslett:frontend-maven-plugin:0.0.23:npm (npm download modules) on project web-ui-docs: Failed to run task: 'npm install --color=false' failed. (error code 34) -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal com.github.eirslett:frontend-maven-plugin:0.0.23:npm (npm download modules) on project web-ui-docs: Failed to run task
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:212)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:116)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:80)
at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build(SingleThreadedBuilder.java:51)
at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:128)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:307)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:193)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:106)
at org.apache.maven.cli.MavenCli.execute(MavenCli.java:863)
at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:288)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:199)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:289)
at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:229)
at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:415)
at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:356)
Caused by: org.apache.maven.plugin.MojoFailureException: Failed to run task
at com.github.eirslett.maven.plugins.frontend.mojo.NpmMojo.execute(NpmMojo.java:62)
at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:134)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:207)
... 20 more
Caused by: com.github.eirslett.maven.plugins.frontend.lib.TaskRunnerException: 'npm install --color=false' failed. (error code 34)
at com.github.eirslett.maven.plugins.frontend.lib.NodeTaskExecutor.execute(NodeTaskExecutor.java:38)
at com.github.eirslett.maven.plugins.frontend.mojo.NpmMojo.execute(NpmMojo.java:59)
... 22 more
-----Message d'origine-----
De : María Arias de Reyna [mailto:delawen@…31…]
Envoyé : vendredi 24 juin 2016 15:43
À : CULOS
Cc : geonetwork-devel@lists.sourceforge.net
Objet : Re: [GeoNetwork-devel] Compilation
On Fri, Jun 24, 2016 at 3:25 PM, CULOS
<xavier.culos@...1076...> wrote:
Hello to everyone, Hi François,
I'm trying to build Geonetwork from sources (tag 3.0.4) under Debian
(jessie), the problem :
the homepage is misinterpreted, it remains {{facet['@label']}}
I do not remember where this pb comes from ! And I can't make speaking
archives.
some tracks ?
- Apache Maven 3.3.9
- NPM version 1.3.23
- in browser, ng-skos.css was not found, neither
bootstrap-table.min.css
Did you do a submodule init and submodule update in git?
And then :
lib.js:438 TypeError: Cannot read property '0' of undefined
at loadContext
(http://cp.mcafee.com/d/1jWVIq6xESyMUUe7fLccCXCQrzASjhOOMqem3qdNOr9EVp
sjudET79ICzBBwQsLCQrLc6zBdB4QsLCM_jcLzRCPWQ1nWSnR2HsiV7oRx3-tyr_mO-Elr
yn8X6I8vPIjrapEVpgs7fZvxRNObaavnKnjjvjV5xxZZ5ZDG8zBHFGThjVkffGhBrwqrhd
LCXCXCM0pCxYE9T79fnuLx7WwQNm9najSsHohwaQ_oS9yG7KWSvfx6yj0Vd9BxcSxV-Cfw
2y8DOVJws-Mr1vF6y0QJxbWwPVCaNaBQfc-uqnjh09llmAvIVlwrpodzFkTW7n7)
at link
(http://cp.mcafee.com/d/1jWVIi6wUSyMUUe7fLccCXCQrzASjhOOMqem3qdNOr9EVp
yn8X6I8vPIjrapEVpgs7fZvxRNObaavnKnjjvjV5xxZZ5ZDG8zBHFGThjVkffGhBrwqrjd
LCXCXCM0pCxYE9T79fnuLx7WwQNm9najSsHohwaQ_oS9yG7KWSvfx6yjzMV9xx4SxV-Cfw
2y8DOVJws-Mr1vF6y0QJxbWwPVCaNaBQfc-uqnjh09llmAvIVlwrpodIcMIDSJg)
- I've turned off web-ui-doc in pom for compilation (otherwise,
field...)
If I remember right, this is related to the map configuration. Are you using a new database?
any suggestions ?
Best regards,
Xavier Culos
Agence de l'eau Adour-Garonne
-------- Attend Shape: An AT&T Tech Expo July 15-16. Meet us at AT&T
Park in San Francisco, CA to explore cutting-edge tech and listen to
tech luminaries present their vision of the future. This family event
has something for everyone, including kids. Get more information and
register today.
http://cp.mcafee.com/d/5fHCNEp3zqb3zwUs-YMOrKrhKejpd7bb1EVodET79ICzBBN
dUSzssCOqemm3hO-rhKYMqekSkjhO-r3ZcO-fmrfHg5vHpvkaJNbAtzm4fVS9LZrbWxlK9
szIqMx_eNdIFCzBB1Ms_R-7n78IEFZuVtddZfAm67TQnSuEyemKCHt5fBgY-F6lK1FJAS-
rKrKr01QglU-k2Kret2uHurgY_j7M1h4jVsSMevodwLQzh0qmMBZgpYP5oBiW7CvfdbFEw
4GGHifSsGMdII6Q6QbYbM6l5t1
GeoNetwork-devel mailing list
http://cp.mcafee.com/d/1jWVIedEIee3xPXP39KVJ6UVdAQsII6zBwSzssCOqemn4Tz
qdNOr9EVpod7bVJ6XP1EVjphd7bVIfQPbUZpI-J0l-JBZgGT4KhSdog_DoC_RILG5mUBOe
NH27YX4SOCqemk71P_nUtssyOyDRXBQQTQ-hoovvhvpWy8VqWqJQk-l3PWApmU6CS3rVKV
KVIDeqR4IM-l9QWBmUSZQ03_0T3VkDj3VkDa3Js8_k6CaNaBQfc-urgY_j7M1h4jVsSMev
odwLQzh0qmMBZgpYP5oBiW7CvfdbFEw4GGHifSsGMdII6Wxj3BTUa
http://cp.mcafee.com/d/1jWVIgdEIee3xPXP39KVJ6UVdAQsII6zBwSzssCOqemn4Tz
NH27YX4SOCqemk71P_nUtssyOyDRXBQQTQ-hoovvhvpWy8VqWqJQk-l3PWApmU6CTPrVKV
KVI07iHsruW01_wryQqyfSDj2fR1FyIiFJ3PZcv054hfBPr0VZwS2_id41Fr2nR1DPclyl
bEupYYQKCy0iGGJ8_pOH0SOMr2Ca
