I’ve just deployed GeoNetwork onto a Unix server, and I find that the geoserver requests are still directed to localhost.
I assume I have to alter the values in config-gui to correct this. Unfortunately, this is inside the geoserver.war, which means either unzip, alter re-zip, or make a build specific to the target machine by editing before building.
Should this be part of the install process? Should this be considered a bug/enhancement?
Justin.
This email is only intended for the person to whom it is addressed and may contain confidential information. If you have received this email in error, please notify the sender and delete this email which must not be copied, distributed or disclosed to any other person.
Unless stated otherwise, the contents of this email are personal to the writer and do not represent the official view of Ordnance Survey. Nor can any contract be formed on Ordnance Survey's behalf via email. We reserve the right to monitor emails and attachments without prior notice.
Thank you for your cooperation.
Ordnance Survey
Romsey Road
Southampton SO16 4GU
Tel: 08456 050505
http://www.ordnancesurvey.co.uk
Hi Justin,
2010/8/2 Justin Rowles (C) <Justin.Rowles@anonymised.com>:
before building.
bug/enhancement?
Maybe we should also move the data and lucene directory also ?
An option could be to define system properties to set lucene, data and
config directories and if not set, use the default one in WEB-INF ?
If doing so, could we use webapp specific name in order to be able to
have more than one node ? something like geonetwork.lucene.dir,
geonetwork1.lucene.dir
Francois
Justin.
Ordnance Survey
Romsey Road
Tel: 08456 050505
The Palm PDK Hot Apps Program offers developers who use the
Plug-In Development Kit to bring their C/C++ apps to Palm for a share
of $1 Million in cash or HP Products. Visit us here for more details:
http://p.sf.net/sfu/dev2dev-palm
GeoNetwork-devel mailing list
