Patrizia, we already have long name in the main page. Do you know other
pages which are displaying short name ?
Not really Tim, I would like to have a list of languages supported by the
current node and that configuration should be set up easily by the
administrator. We already have a complete list of languages in the ISO19115
schema.
For instance, if you want to change default language, you need to edit the
config.xml; if you want to hide or add languages in the banner, you need to
update the banner.xsl; and now I need a list of language available for
thesaurus.
So I would prefer to have all this options into the config.xml.
Clearly we will continu to use ISO_639 ... and maybe move to alpha-3 code
space ...
Francois
-----Message d'origine-----
De : geonetwork-devel-bounces@lists.sourceforge.net
[mailto:geonetwork-devel-bounces@lists.sourceforge.net] De la part de Tim
Jacobs
Envoyé : mardi 2 janvier 2007 11:10
À : fx.prunayre@anonymised.com; geonetwork-devel@lists.sourceforge.net
Objet : Re: [GeoNetwork-devel] Config.xml for languages
Hi Frangois,
Happy New Year to you too!
If I understand you correctly, you want to have a more or less complete list
of language codes like "en", "fr", etc, to add them to config.xml, right?
Those are defined by ISO, and more or less copied by IANA (USA) for web/XML
use.
Check out for instance:
http://en.wikipedia.org/wiki/ISO_639 and the further links on that page.
Greetings,
Tim
From: Frangois Prunayre <fx.prunayre@anonymised.com>
To: <geonetwork-devel@lists.sourceforge.net>
Subject: [GeoNetwork-devel] Config.xml for languages
Date: Tue, 2 Jan 2007 10:52:55 +0100
Hi list (& happy new year 2oo7),
I'm currently working on the integration of thesaurus manager into
Geonetwork.
For thesaurus editing, I need to have a list of languages available for
user.
I would like to change the config.xml for language which is :
<language>en</language>
which only set up the default language as "en" for example.
by something like :
<languages>
<language default="true" thesaurus="true">en</language>
<language thesaurus="true">fr</language>
<language>es</language>
<language>cn</language>
</languages>
which will set :
- default language "en"
- language available for thesaurus edition "en" and "fr"
- languages available for the application : "en","fr","es","cn".
That way we could also manage to remove language from the menu using
the config.xml and not using the XSL banner.xsl.
Any comments ?
I hope to be able to have a first online demo for thesaurus next week.
Francois
Ce message a ete verifie par MailScanner pour des virus ou des
polluriels et rien de suspect n'a ete trouve.
Les donnees et renseignements contenus dans ce message sont personnels,
confidentiels et prives. Toute publication, utilisation ou diffusion,
meme partielle, doit etre autorisee.
Any data and information contained in this electronic mail is personal,
confidential and secret. Any total or partial publication, use or
distribution must be authorized.
-- Take Surveys. Earn Cash. Influence the Future of IT Join
SourceForge.net's Techsay panel and you'll get the chance to share your
opinions on IT & business topics through brief surveys - and earn cash
http://www.techsay.com/default.php?page=join.php&p=sourceforge&CID=DEVD
EV
GeoNetwork-devel mailing list
_________________________________________________________________
Who is the sweetheart of the Japanese and always holds something in his
hands? Live Search knows! How about you?
http://search.live.com/images/results.aspx?q=Manneken%20pis&FORM=QBIR
Ce message a ete verifie par MailScanner pour des virus ou des polluriels et
confidentiels et prives. Toute publication, utilisation ou diffusion, meme
Ce message a ete verifie par MailScanner pour des virus ou des polluriels et rien de suspect n'a ete trouve.
Les donnees et renseignements contenus dans ce message sont personnels, confidentiels et prives. Toute publication, utilisation ou diffusion, meme partielle, doit etre autorisee.
Any data and information contained in this electronic mail is personal, confidential and secret. Any total or partial publication, use or distribution must be authorized.
