Hi list!
I have been trying to set up elasticsearch (installed 7.2.x ) in my Geonetwork 3.10.2 in a debian server
I have been following the instructions on: https://geonetwork-opensource.org/manuals/3.10.x/en/maintainer-guide/installing/installing-index.html#
I haven’t been able to create the default index, when I try to execute:
curl -X PUT http://localhost:9200/gn-features -H ‘Content-Type: application/json’ -d @features.json
I got this error:
{“error”:“Content-Type header [application/x-www-form-urlencoded] is not supported”,“status”:406}
So I added the Content-Type:
cd /tmp
curl -O https://raw.githubusercontent.com/geonetwork/core-geonetwork/3.4.x/es/config/features.json
curl -O https://raw.githubusercontent.com/geonetwork/core-geonetwork/3.4.x/es/config/records.json
curl -X PUT http://localhost:9200/gn-records -H ‘Content-Type: application/json’-d @records.json
curl -O https://raw.githubusercontent.com/geonetwork/core-geonetwork/3.4.x/es/config/searchlogs.json
curl -X PUT http://localhost:9200/gn-searchlogs -d @searchlogs.json -H ‘Content-Type: application/json’
But I still get errors:
“error” : {
“root_cause” : [
“type” : “mapper_parsing_exception”,
“reason” : “Root mapping definition has unsupported parameters: [default : {properties={fieldLowerValue={type=keyword}, documentType={type=keyword}, recordType={type=keyword}, query={type=keyword}, spatialFilter={type=keyword}, autogenerated={type=keyword}, language={type=keyword}, fieldValue={type=keyword}, hits={type=integer}, path={type=keyword}, fieldUpperValue={type=keyword}, field={type=keyword}, similarity={type=keyword}, host={type=keyword}, isSimple={type=keyword}, sortBy={type=keyword}, location={type=geo_point}, id={type=keyword}, timestamp={type=date}}}]”
“reason” : “Failed to parse mapping [_doc]: Root mapping definition has unsupported parameters: [default : {properties={fieldLowerValue={type=keyword}, documentType={type=keyword}, recordType={type=keyword}, query={type=keyword}, spatialFilter={type=keyword}, autogenerated={type=keyword}, language={type=keyword}, fieldValue={type=keyword}, hits={type=integer}, path={type=keyword}, fieldUpperValue={type=keyword}, field={type=keyword}, similarity={type=keyword}, host={type=keyword}, isSimple={type=keyword}, sortBy={type=keyword}, location={type=geo_point}, id={type=keyword}, timestamp={type=date}}}]”,
“caused_by” : {
“status” : 400
What am I doing wrong? I’m little lost, so any help configuring elastic will be much appreciated.
Thanks
Malena
