[GeoNetwork-devel] Creating a new template
Hi everyone. I'd like to make a custom template, but I'm getting a little hung up on how to go about doing so. I've found the default templates in WEB-INF/classes/setup/templates, but when I add a new one, it doesn't show up in the template list inside the app. Are these templates registered somewhere?
Thanks for any help,
Ryan
Im interested on this topic too… Thanks.
On Mon, Aug 23, 2010 at 10:02 AM, Ryan Zoerb <razoerb@anonymised.com> wrote:
Hi everyone. I’d like to make a custom template, but I’m getting a little hung up on how to go about doing so. I’ve found the default templates in WEB-INF/classes/setup/templates, but when I add a new one, it doesn’t show up in the template list inside the app. Are these templates registered somewhere?
Ryan
This SF.net email is sponsored by
Make an app they can’t live without
Enter the BlackBerry Developer Challenge
http://p.sf.net/sfu/RIM-dev2dev
GeoNetwork-devel mailing list
Visita:
www.infocussite.com
www.infocussite.com/mancala/
hi,
how do you add your new template ?
If you import an XML file you can say in the page where you select the file that it is a template. If you’re using the GeoNetwork editor, you can sa at the bottom of the page that this should be saved as a template. In any case you should also check the privileges – if you want the templae available to everyone, make sure it is visible to group “all”.
Does this help you ?
Kind regards
Heikki Doeleman
2010/8/23 Samuel Chávez <samuelchvez@anonymised.com>
Ryan
Visita:
www.infocussite.com
As we are rolling out GN in our company the inevitable happens, people say both that the ISO19139 schema is too complex and that they also want to add more features to it.
I could create a new profile but I want to do as much as possible in the standard system before I take that path. The closest starting point to our requirements is the MCP profile.
Here are the changes I wish to make.
1) The ANZLIC-theme.xml codelist for thematic classification of resources would be replaced with a Water and Atmosphere specific one.
i.e AGRICULTURE-Crops to WATER-Wetlands would be replaced with abalone to zooplankton
2) The mcp-allgens.xml MCP Geographic Extent Name Register which lists regions specific to Australia would be replaced with one listing regions specific to New Zealand and Antartica.
Can I gently point out that the NZ in ANZLIC is supposed to be New Zealand and yet NZ is conspicously absent from these ANZLIC standards.
3) We wish to add a project code to the metadata record indicating the project that generated the data.
Is creating a new profile the only way of achieving this?
Thanks Andrew
Andrew Watkins
Systems Development Team Manager
National Institute Water & Atmospheric Research (NIWA).
NIWA is the trading name of the National Institute of Water & Atmospheric Research Ltd.
Thanks for the response Heikki. So that’s how you manually add a template, is there any way to add the template somewhere in the GeoNetwork war and have it automatically show up in the template list on startup? I found that if you put a template in one of the existing folders under setup/templates, it will show up, but not if you add your own. Is there any way to, for example, add a ‘test’ folder alongside ‘19139’, ‘19115’, …?
Ryan
On Aug 23, 2010, at 4:32 PM, heikki wrote:
hi,
Kind regards
Heikki Doeleman
Ryan
Visita:
www.infocussite.com
2010/8/25 Ryan Zoerb <razoerb@anonymised.com>:
Thanks for the response Heikki. So that's how you manually add a template,
example, add a 'test' folder alongside '19139', '19115', ...?
Templates are loaded from the administration interface.
Add or remove templates in the WEB-INF/classes/setup/templates
directory and load them for one or more schema from the admin
interface. They have to be in one specific schema directory not in a
test folder
Cheers.
Francois
Ryan
hi,
that it is a template. If you're using the GeoNetwork editor, you can sa at
you should also check the privileges -- if you want the templae available to
everyone, make sure it is visible to group "all".
Kind regards
Heikki Doeleman
Im interested on this topic too... Thanks.
Ryan
Make an app they can't live without
Visita:
www.infocussite.com
Sell apps to millions through the Intel(R) Atom(Tm) Developer Program
Be part of this innovative community and reach millions of netbook users
worldwide. Take advantage of special opportunities to increase revenue and
speed time-to-market. Join now, and jumpstart your future.
http://p.sf.net/sfu/intel-atom-d2d
