[GeoNetwork-devel] CSW
Hi guys.
I've downloaded and compiled geonetwork from the CVS and I've seen a mistake with the CSW. I've added 3 metadata in my database that can be retrieved using the Z39.50 protocol, but when I send this CSW query:
<GetRecords service="http://www.opengis.net/cat/csw&quot; version="2.0.1" xmlns="http://www.opengis.net/cat/csw&quot; xmlns:ogc="http://www.opengis.net/ogc&quot; xmlns:gml="http://www.opengis.net/gml&quot; startPosition='1' maxRecords='10' outputSchema="csw:IsoRecord" resultType="results">
    <Query >
        <ElementSetName>full</ElementSetName>
        <Constraint version='1.1.0'>
            <ogc:Filter xmlns:ogc="http://www.opengis.net/ogc&quot;&gt;
                <ogc:Or>
                    <ogc:PropertyIsLike wildCard="*" singleChar="?" escape="\">
                        <ogc:PropertyName>Title</ogc:PropertyName>
                        <ogc:Literal>*a*</ogc:Literal>
                    </ogc:PropertyIsLike>
                        <ogc:PropertyName>Abstract</ogc:PropertyName>
                </ogc:Or>
            </ogc:Filter>
        </Constraint>
    </Query>
</GetRecords>
I receive this answer:
<csw:GetRecordsResponse xmlns:csw="http://www.opengis.net/cat/csw&quot;&gt;
  <csw:SearchStatus status="complete" />
  <csw:SearchResults numberOfRecordsMatched="3" numberOfRecordsReturned="3" elementSet="full" />
</csw:GetRecordsResponse>
The numberOfRecordsMatched param is Ok, but the retrieved medatada aren't in the XML tree. It is a problem of the CVS version?
Regards.
Jorge Piera Llodra
Equipo de desarrollo gvSIG
Conselleria de Infraestructuras y Transporte
Generalitat Valenciana
Valencia - Spain
http://www.gvsig.gva.es
Hi Jorge,
I think I have finally found the problem of this behaviour. If you get
with an empty result set you are probably quering 19115 metadata
not 19139 ones. In this case you should see an error log like this one:
SearchController : Metadata not found or invalid schema : <id>
Hi guys.
www.opengis.net/ogc" xmlns:gml="http://www.opengis.net/gml&quot;
    <Query >
                <ogc:Or>
escape="\">
escape="\">
                </ogc:Or>
            </ogc:Filter>
        </Constraint>
    </Query>
</GetRecords>
Regards.
