[GeoNetwork-devel] Debugging XSLT
Hello ,
I came across this link for debugging XSLT
http://trac.osgeo.org/geonetwork/wiki/HowToDebug
I tried with Xalan Command Line and also XSL Transformation in Eclipse and I
get the following error. Can any one please let me know what is going wrong?
Thanks.
Regards
Kumaran
Command Line command executed
java org.apache.xalan.xslt.Process -IN C:\metadata.xml -XSL
C:\project\workspace\geonetwork\web\src\main\webapp\xsl\metadata-edit.xsl
-OUT output.html -HTML
Output
SystemId Unknown; Line #44; Column #117; Could not find function: lower-case
SystemId Unknown; Line #44; Column #117; Expected ), but found: ,
(Location of error unknown)java.lang.ClassCastException:
org.apache.xpath.object
s.XString cannot be cast to java.lang.String
Xalan: was not successful.
(Location of error unknown)XSLT Error (java.lang.RuntimeException): Xalan:
was n
ot successful.
Exception in thread "main" java.lang.RuntimeException: Xalan: was not
successful
        at org.apache.xalan.xslt.Process.doExit(Process.java:1155)
        at org.apache.xalan.xslt.Process.main(Process.java:1128)
Yes, when I wrote those instructions,
GeoNetwork used Xalan. Now it uses
Saxon, and many XSL scripts make use
of XSLT 2 functions (such as lower-case)
that are not implemented by Xalan.
You must use Saxon.
Richard Walker
Software Improvements Pty Ltd
Phone: +61 2 6273 2055
Fax: +61 2 6273 2082
Hello Richard Walker,
Thanks.
Can you please let me know how to debug using Saxon? Some examples or tips
will be really helpful? Thanks
Regards
Kumaran
-----Original Message-----
From: Software Improvements gn-devel [mailto:gn-devel@anonymised.com]
Sent: Wednesday, March 30, 2011 10:09 AM
To: geonetwork-devel@lists.sourceforge.net
Subject: Re: [GeoNetwork-devel] Debugging XSLT
and I get the following error.
lower-case
of XSLT 2 functions (such as lower-case) that are not implemented by Xalan.
You must use Saxon.
Richard Walker
Enable your software for Intel(R) Active Management Technology to meet the
growing manageability and security demands of your customers. Businesses are
taking advantage of Intel(R) vPro (TM) technology - will your software be a
part of the solution? Download the Intel(R) Manageability Checker today!
http://p.sf.net/sfu/intel-dev2devmar
GeoNetwork-devel mailing list
I tried with Salan in Eclipse and I get the following error am I doing
anything wrong?
11:24:09,279 INFO [main] Main -
javax.xml.transform.TransformerFactory=null
11:24:09,326 INFO [main] Main -
java.endorsed.dirs=C:\jdk1.6.0_24\jre\lib\endorsed
11:24:09,420 INFO [main] Main - launchFile:
C:\project\workspace\.metadata\.plugins\org.eclipse.wst.xsl.jaxp.launching\l
aunch\launch.xml
11:24:12,404 ERROR [main] JAXPSAXProcessorInvoker - Syntax error in 'if
($attribute=true()) then concat(../geonet:element/@ref, '_', name(.)) else
geonet:element/@ref'.
file:/C:/project/workspace/geonetwork/web/src/main/webapp/xsl/metadata.xsl:
line 1860: Error parsing XPath expression 'if ($attribute=true()) then
concat(../geonet:element/@ref, '_', name(.)) else geonet:element/@ref'.
line 1860: Required attribute 'select' is missing.
11:24:12,436 ERROR [main] JAXPSAXProcessorInvoker - Could not compile
stylesheet
javax.xml.transform.TransformerConfigurationException: Could not compile
stylesheet
  at
com.sun.org.apache.xalan.internal.xsltc.trax.TransformerFactoryImpl.newTempl
ates(TransformerFactoryImpl.java:828)
  at
com.sun.org.apache.xalan.internal.xsltc.trax.TransformerFactoryImpl.newTrans
former(TransformerFactoryImpl.java:617)
  at
formerHandler(TransformerFactoryImpl.java:903)
  at
org.eclipse.wst.xsl.jaxp.debug.invoker.internal.JAXPSAXProcessorInvoker.addS
tylesheet(JAXPSAXProcessorInvoker.java:136)
  at
tylesheet(JAXPSAXProcessorInvoker.java:127)
  at
org.eclipse.wst.xsl.jaxp.debug.invoker.PipelineDefinition.addStyleSheet(Pipe
lineDefinition.java:161)
  at
org.eclipse.wst.xsl.jaxp.debug.invoker.PipelineDefinition.configure(Pipeline
Definition.java:152)
  at
org.eclipse.wst.xsl.jaxp.debug.invoker.internal.Main.main(Main.java:72)
11:24:12,498 FATAL [main] Main - Error with stylesheet:
file:/C:/project/workspace/geonetwork/web/src/main/webapp/xsl/metadata-edit.
xsl
org.eclipse.wst.xsl.jaxp.debug.invoker.internal.ConfigurationException:
xsl
  at
lineDefinition.java:163)
  at
  at
[mailto:kumaran.narayanaswamy@anonymised.com]
Sent: Wednesday, March 30, 2011 10:59 AM
To: 'Software Improvements gn-devel'; geonetwork-devel@lists.sourceforge.net
Thanks.
Regards
Kumaran
lower-case
You must use Saxon.
Richard Walker
