[GeoNetwork-devel] Debugging XSLT
I am trying to implement some things to iso19139 inspire edit template. For
example I have problem with custom helpers. How can I debug (how you
developers debug it?) the whole process of generating edit metadata UI?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Debugging-XSLT-tp5320164.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
Hi
Thats a tricky stuff, the xslt used in the editor are not that simple to test in 3rd party apps like Oxygen or XMLSpy, so finally what I do is to use xsl:message in the xslt templates in development mode (note that if you use a war file and don’t build with -Penv-dev, this will not work as xslt are cached.
In 3.x versions, the editor is build with https://github.com/geonetwork/core-geonetwork/blob/develop/web/src/main/webapp/xslt/ui-metadata/form-builder.xsl and https://github.com/geonetwork/core-geonetwork/blob/develop/web/src/main/webapp/xslt/ui-metadata/form-configurator.xsl
that delegate to the templates defined in each schema like https://github.com/geonetwork/core-geonetwork/blob/develop/schemas/iso19139/src/main/plugin/iso19139/layout/layout.xsl to render each element.
If you want to check some issue with helpers probably you have to start checking in form-builder.xsl and form-configurator.xsl
Jose García
On Thu, May 11, 2017 at 1:39 PM, amacar <amadej.pevec@anonymised.com> wrote:
GeoNetwork-devel mailing list
GeoNetwork-devel@…537…sourceforge.net
Vriendelijke groeten / Kind regards,
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
T: +31 (0)318 416664
Please consider the environment before printing this email.
Thank you. Yes I forgot to mentioned that I am using version 3.0.2 with
eclipse and included jetty. I think that /xsl:message/ is good enough to
start with. So if I want to see this xsl:message in returned page I need to
add /-Penv-dev/ parameter to VM arguments in eclipse or where is this
development mode settings? I don't want to stop and start geonetwork
everytime I change something. I am using /?debug/ parameter but it is not
helping.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Debugging-XSLT-tp5320164p5320169.html
