[GeoNetwork-devel] Display elements no existing in the metadata xml in a custom view
Hi
I want to display 2 fields for gmd:equivalentScale and gmd:distance in a custom view. The gmd:spatialResolution can be missing in the metadata, so if possible display them anyway or at least display the button to add them
According to config-editor.xsd doc:
  • To display a field if exist in the metadata document or providing a add button in case it does not exist (specify in and or attribute):
  • Activate the “flat” mode at the tab level to make the form display only existing elements
  1. The add buttons are rendered, but both using the label defined for spatialResolution, so it’s confusing. Both buttons require to have the following (see full snippet below), if changed name or or attributes, the buttons are not displayed:
<action type=“add” name=“spatialResolution” or=“spatialResolution”
in=“/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification”
Is possible to setup a custom label for the actions?
  1. Also tried to add in the view flatModeExceptions for the following elements, expecting that then would the fields would be displayed even if not in the xml and even if no Add buttons are configured, but no success:
Not sure if I’m missing something here or what I expect is not correct?
Vriendelijke groeten / Kind regards,
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
T: +31 (0)318 416664
Please consider the environment before printing this email.
2016-07-07 13:16 GMT+02:00 Jose Garcia <jose.garcia@anonymised.com>:
Hi
See https://github.com/geonetwork/core-geonetwork/blob/develop/schemas/config-editor.xsd#L1083
An easier way of doing this could be to use @if instead of @or/@in+flat
https://github.com/geonetwork/core-geonetwork/blob/develop/schemas/config-editor.xsd#L1011
Francois
This is the snippet for the fields configuration:
<field
name=“equivalentScale”
xpath=“/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:spatialResolution/gmd:MD_Resolution/gmd:equivalentScale”
or=“equivalentScale”
in=“/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:spatialResolution/gmd:MD_Resolution/*” />
gmd:MD_Resolution
gmd:equivalentScale
gmd:MD_RepresentativeFraction
gmd:denominator
gco:Integer</gco:Integer>
</gmd:denominator>
</gmd:MD_RepresentativeFraction>
</gmd:equivalentScale>
</gmd:MD_Resolution>
</gmd:spatialResolution>
<field
name=“distance”
xpath=“/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:spatialResolution/gmd:MD_Resolution/gmd:distance”
or=“distance”
gmd:MD_Resolution
gmd:distance
gco:Distance</gco:Distance>
</gmd:distance>
Jose García
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
Attend Shape: An AT&T Tech Expo July 15-16. Meet us at AT&T Park in San
Francisco, CA to explore cutting-edge tech and listen to tech luminaries
present their vision of the future. This family event has something for
everyone, including kids. Get more information and register today.
http://sdm.link/attshape
GeoNetwork-devel mailing list
Hi Francois
See feedback inline.
Jose García
On Thu, Jul 7, 2016 at 1:33 PM, Francois Prunayre <fx.prunayre@anonymised.com> wrote:
Ok, I have an old version of develop and the xsd seem not updated with that, but the attribute works. That’s much better.
Just to be sure, you mean that I can use this and that should display the button also?:
But this doesn’t show the input text if the element is missing in the xml without requiring any button. Is there’re any way to do that? From the documentation, seem it says that.
2016-07-07 13:16 GMT+02:00 Jose Garcia <jose.garcia@anonymised.com…437…>:
Hi
Francois
<field
gmd:MD_Resolution
gmd:equivalentScale
gmd:denominator
</gmd:denominator>
<field
name=“distance”
or=“distance”
gmd:MD_Resolution
gmd:distance
</gmd:distance>
Jose García
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
2016-07-07 13:51 GMT+02:00 Jose Garcia <jose.garcia@anonymised.com>:
Hi Francois
Jose García
wrote:
Hi
to add them
   - To display a field if exist in the metadata document or providing
   a add button in case it does not exist (specify ``in`` and ``or``
   attribute):
   - Activate the "flat" mode at the tab level to make the form display
1) The add buttons are rendered, but both using the label defined for
spatialResolution, so it's confusing. Both buttons require to have the
following (see full snippet below), if changed *name* or *or*
<action type="add" name="spatialResolution" or="spatialResolution"
in="/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification"
See
that, but the attribute works. That's much better.
2) Also tried to add in the view flatModeExceptions for the following
      <flatModeExceptions>
        <for name="gmd:spatialResolution"/>
        <for name="gmd:equivalentScale"/>
        <for name="gmd:distance"/>
      </flatModeExceptions>
Not sure if I'm missing something here or what I expect is not correct?
button also?:
if="count(/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:spatialResolution/gmd:MD_Resolution/gmd:distance)
= 0">
But this doesn't show the input text if the element is missing in the xml
without requiring any button. Is there're any way to do that? From the
Not 100% sure, but if not using a template mode field, then it can't
display an input if the field is not in the XML. Would need some testing...
Francois
Francois
<field
name="equivalentScale"
xpath="/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:spatialResolution/gmd:MD_Resolution/gmd:equivalentScale"
or="equivalentScale"
in="/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:spatialResolution/gmd:MD_Resolution/*"
if="count(/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:spatialResolution/gmd:MD_Resolution/gmd:equivalentScale)
= 0">
<template>
  <snippet>
    <gmd:spatialResolution>
      <gmd:MD_Resolution>
        <gmd:equivalentScale>
          <gmd:MD_RepresentativeFraction>
            <gmd:denominator>
              <gco:Integer></gco:Integer>
            </gmd:denominator>
  </snippet>
</template>
</action>
<field
name="distance"
xpath="/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:spatialResolution/gmd:MD_Resolution/gmd:distance"
or="distance"
<action type="add" name="spatialDistance" or="spatialDistance"
= 0">
<template>
  <snippet>
      <gmd:MD_Resolution>
        <gmd:distance>
          <gco:Distance></gco:Distance>
        </gmd:distance>
  </snippet>
</template>
</action>
Jose García
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/&gt;Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664> <https://www.facebook.com/geocatbv&gt;
<https://twitter.com/geocat_bv&gt;
<https://plus.google.com/u/1/+GeocatNetbv/posts&gt;Please consider the
environment before printing this email.*
Hi
I have just tried this quickly:
But the field is not displayed. In any case, with the button label, it’s ok for now, thanks.
Jose García
On Thu, Jul 7, 2016 at 1:54 PM, Francois Prunayre <fx.prunayre@anonymised.com> wrote:
Hi Francois
Jose García
Not 100% sure, but if not using a template mode field, then it can’t display an input if the field is not in the XML. Would need some testing…
Francois
if=“count(/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:spatialResolution/gmd:MD_Resolution/gmd:distance) = 0”>
But this doesn’t show the input text if the element is missing in the xml without requiring any button. Is there’re any way to do that? >From the documentation, seem it says that.
Hi
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
Francois
<field
gmd:MD_Resolution
gmd:equivalentScale
gmd:denominator
</gmd:denominator>
<field
name=“distance”
or=“distance”
gmd:MD_Resolution
gmd:distance
</gmd:distance>
Jose García
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
2016-07-07 14:02 GMT+02:00 Jose Garcia <jose.garcia@anonymised.com>:
Hi
in a template field you need to define key/value with xpath to define which
part of the XML to edit. If none, then no form. This is used to create the
appropriate inputs.
Francois
<field
  xpath="/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:spatialResolution"
  in="/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/*">
  <template>
    <snippet>
      <gmd:MD_Resolution>
        <gmd:distance>
        </gmd:distance>
    </snippet>
  </template>
</field>
  <for name="gmd:spatialResolution"></for>
  <for name="gmd:distance"></for>
But the field is not displayed. In any case, with the button label, it's
ok for now, thanks.
Jose García
Hi Francois
Jose García
> wrote:
Hi
to add them
   providing a add button in case it does not exist (specify ``in`` and ``or``
   attribute):
See
the button also?:
= 0">
xml without requiring any button. Is there're any way to do that? From the
Francois
Francois
<field
= 0">
<template>
  <snippet>
      <gmd:MD_Resolution>
            <gmd:denominator>
            </gmd:denominator>
  </snippet>
</template>
</action>
<field
name="distance"
or="distance"
= 0">
<template>
  <snippet>
      <gmd:MD_Resolution>
        <gmd:distance>
        </gmd:distance>
  </snippet>
</template>
</action>
Jose García
luminaries
