[GeoNetwork-devel] Docker Official Image for GeoNetwork
As of today, GeoNetwork does not have an official docker image yet.
The idea behind official images is to have reliable images, built on best practices, which can in one hand be reused as base images, and on the other hand, be adopted by users who just want to try the software without the “headaches” of configuring it.
Having an official image of GeoNetwork, which is easy to use, but at the same time flexible enough to allow (near-)production configuration, could be a great benefit for current, or potential GeoNetwork users.
I made a pull request for adding such image to the official docker repository. It is currently supporting the latest releases of GeoNetwork (3.0.5 and 3.2.0), but the idea is to keep maintaining it, by adding new releases.
Before going further, I would like to know if I can count with the “blessing” of the GeoNetwork upstream team regarding this official image, or if you have any concerns.
In case you want to check out the code, the official image is made of a series of repositories. This one has the actual code:
https://github.com/GeoCat/geonetwork-official-images
While this one has the documentation:
https://github.com/GeoCat/docs/tree/geonetwork/geonetwork
If you want to contribute to this image, by all means feel free to do so.
Thanks in advance for your feedback.
Best wishes,
Joana
Vriendelijke groeten / Kind regards,
Joana Simoes
Veenderweg 13
6721 WD Bennekom
The Netherlands
T: +31 (0)318 416664
GeoCat bv
http://geocat.net
Hi Joana
+1 for me, but I think should be moved to the GitHub GeoNetwork repository instead of the actual GeoCat repository.
Jose García
On Thu, Nov 3, 2016 at 9:43 AM, Joana Simoes <joana.simoes@anonymised.com> wrote:
Best wishes,
Joana
Joana Simoes
Veenderweg 13
6721 WD Bennekom
The Netherlands
GeoCat bv
http://geocat.net
Joana Simoes
Veenderweg 13
6721 WD Bennekom
The Netherlands
GeoCat bv
http://geocat.net
Developer Access Program for Intel Xeon Phi Processors
Access to Intel Xeon Phi processor-based developer platforms.
With one year of Intel Parallel Studio XE.
Training and support from Colfax.
Order your platform today. http://sdm.link/xeonphi
GeoNetwork-devel mailing list
GeoNetwork-devel@…537…sourceforge.net
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
Please consider the environment before printing this email.
+1 to making the image really official instead of a "GeoCat" flavour.
