[GeoNetwork-devel] Documentation code freeze!
The mkdocs transition (https://github.com/geonetwork/core-geonetwork/wiki/Proposal-mkdocs.md) is presently in progress :slightly_smiling_face:
And this is just a notice that the docs repository (https://github.com/geonetwork/doc) should be considered frozen/archived.
Any content you add to the manual after this point will not be picked up!!
If the admin’s can close the repository for writing it would be best!?
Jody Garnett
Done
Thanks Jody
Jody Garnett
camptocamp
INNOVATIVE SOLUTIONS
BY OPEN SOURCE EXPERTS
Florent Gravin
Head of Technology Geospatial
I have created the draft PR here: https://github.com/geonetwork/core-geonetwork/pull/7329
You can see work in progress here https://jodygarnett.github.io/core-geonetwork/api/
It is taking a while to do each section, but I have improved the conversion script to do batches of pages at a time:
python3 -m translate rst docs/api/*.rst
Notes:
  • I am able to fix simple formatting
  • There are few enough notes and warnings that I am fixing them by hand
  • absolute references between pages, example :ref:csw-configuration, end up as broken links
Jody Garnett
Jody Garnett
camptocamp
Florent Gravin
The PR is now code complete with all files translated to markdown.
Visual review is available here https://jodygarnett.github.io/core-geonetwork/
  • I am interested in ensuring all the content has made it across safely
    I am especially interested in all the complicated javascript and xml examples
  • The content is now 100% translated using my wrapper script around pandoc:
    python3 -m translate rst manual/docs/**/*.rst
  • This “success” of this script makes it easier to correct or simplify the origional rst files (for such things as incorrect indenting) then to fix up the resulting markdown
  • I made a script to fix the broken “reference” links between pages but have not run it yet
  • Micheal has been experiment with the appearance and may enjoy your feedback also
The PR does have a conflict - some doc/version*.txt files were spell-checked (but I do not have write access to resolve conflicts):
docs/changes2.1.x.txt
docs/changes2.2.x.txt
docs/changes3.8.0-0.txt
Jody Garnett
Jody Garnett
Jody Garnett
camptocamp
Florent Gravin
