[GeoNetwork-devel] Edit the ISO metadata
Dear,
I installed the 3.0.4 version of Geonetwork and I can not edit the ISO metadata, because the application does not display the form. It features an almost empty page .
It required some additional configuration ?
Is there any javascript errors? Is there any errors on the log?
María.
On Thu, May 12, 2016 at 4:14 AM, Idélcio Filho <isafilho@anonymised.com> wrote:
Dear,
almost empty page .
Mobile security can be enabling, not merely restricting. Employees who
bring their own devices (BYOD) to work are irked by the imposition of MDM
restrictions. Mobile Device Manager Plus allows you to control only the
apps on BYO-devices by containerizing them, leaving personal data untouched!
https://ad.doubleclick.net/ddm/clk/304595813;131938128;j
GeoNetwork-devel mailing list
As of version 2.10.3 , the Geonetwork is not fully compatible with the Portuguese language ( EN ) , the application does not natively display the registration form metadata in this language.
mai 12, 2016 9:08:35 AM org.apache.catalina.startup.ClassLoaderFactory validateFile
ADVERTÊNCIA: Problem with directory [/usr/share/tomcat8/common/classes], exists: [false], isDirectory: [false], canRead: [false]
ADVERTÊNCIA: Problem with directory [/usr/share/tomcat8/common], exists: [false], isDirectory: [false], canRead: [false]
ADVERTÊNCIA: Problem with directory [/usr/share/tomcat8/server/classes], exists: [false], isDirectory: [false], canRead: [false]
ADVERTÊNCIA: Problem with directory [/usr/share/tomcat8/server], exists: [false], isDirectory: [false], canRead: [false]
ADVERTÊNCIA: Problem with directory [/usr/share/tomcat8/shared/classes], exists: [false], isDirectory: [false], canRead: [false]
ADVERTÊNCIA: Problem with directory [/usr/share/tomcat8/shared], exists: [false], isDirectory: [false], canRead: [false]
mai 12, 2016 9:08:36 AM org.apache.catalina.startup.VersionLoggerListener log
INFORMAÇÕES: Server version:        Apache Tomcat/8.0.32 (Ubuntu)
INFORMAÇÕES: Server built:          Feb 5 2016 08:20:39 UTC
INFORMAÇÕES: Server number:         8.0.32.0
INFORMAÇÕES: OS Name:               Linux
INFORMAÇÕES: OS Version:            4.4.0-22-generic
INFORMAÇÕES: Architecture:          amd64
INFORMAÇÕES: Java Home:             /usr/lib/jvm/java-8-openjdk-amd64/jre
INFORMAÇÕES: JVM Version:           1.8.0_91-8u91-b14-0ubuntu4~16.04.1-b14
INFORMAÇÕES: JVM Vendor:            Oracle Corporation
INFORMAÇÕES: CATALINA_BASE:         /var/lib/tomcat8
INFORMAÇÕES: CATALINA_HOME:         /usr/share/tomcat8
INFORMAÇÕES: Command line argument: -Djava.util.logging.config.file=/var/lib/tomcat8/conf/logging.properties
INFORMAÇÕES: Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager
INFORMAÇÕES: Command line argument: -Djava.awt.headless=true
INFORMAÇÕES: Command line argument: -Xmx768m
INFORMAÇÕES: Command line argument: -XX:+UseConcMarkSweepGC
INFORMAÇÕES: Command line argument: -Djava.endorsed.dirs=/usr/share/tomcat8/endorsed
INFORMAÇÕES: Command line argument: -Dcatalina.base=/var/lib/tomcat8
INFORMAÇÕES: Command line argument: -Dcatalina.home=/usr/share/tomcat8
INFORMAÇÕES: Command line argument: -Djava.io.tmpdir=/tmp/tomcat8-tomcat8-tmp
mai 12, 2016 9:08:37 AM org.apache.coyote.AbstractProtocol init
INFORMAÇÕES: Initializing ProtocolHandler ["http-nio-8080"]
mai 12, 2016 9:08:37 AM org.apache.tomcat.util.net.NioSelectorPool getSharedSelector
INFORMAÇÕES: Using a shared selector for servlet write/read
mai 12, 2016 9:08:37 AM org.apache.catalina.startup.Catalina load
INFORMAÇÕES: Initialization processed in 1396 ms
mai 12, 2016 9:08:37 AM org.apache.catalina.core.StandardService startInternal
INFORMAÇÕES: Starting service Catalina
mai 12, 2016 9:08:37 AM org.apache.catalina.core.StandardEngine startInternal
INFORMAÇÕES: Starting Servlet Engine: Apache Tomcat/8.0.32 (Ubuntu)
mai 12, 2016 9:08:37 AM org.apache.catalina.startup.HostConfig deployDescriptor
INFORMAÇÕES: Deploying configuration descriptor /etc/tomcat8/Catalina/localhost/manager.xml
mai 12, 2016 9:08:38 AM org.apache.jasper.servlet.TldScanner scanJars
INFORMAÇÕES: At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
mai 12, 2016 9:08:38 AM org.apache.catalina.startup.HostConfig deployDescriptor
INFORMAÇÕES: Deployment of configuration descriptor /etc/tomcat8/Catalina/localhost/manager.xml has finished in 1,802 ms
INFORMAÇÕES: Deploying configuration descriptor /etc/tomcat8/Catalina/localhost/docs.xml
mai 12, 2016 9:08:39 AM org.apache.jasper.servlet.TldScanner scanJars
mai 12, 2016 9:08:39 AM org.apache.catalina.startup.HostConfig deployDescriptor
INFORMAÇÕES: Deployment of configuration descriptor /etc/tomcat8/Catalina/localhost/docs.xml has finished in 666 ms
INFORMAÇÕES: Deploying configuration descriptor /etc/tomcat8/Catalina/localhost/host-manager.xml
mai 12, 2016 9:08:40 AM org.apache.jasper.servlet.TldScanner scanJars
mai 12, 2016 9:08:40 AM org.apache.catalina.startup.HostConfig deployDescriptor
INFORMAÇÕES: Deployment of configuration descriptor /etc/tomcat8/Catalina/localhost/host-manager.xml has finished in 652 ms
INFORMAÇÕES: Deploying configuration descriptor /etc/tomcat8/Catalina/localhost/examples.xml
mai 12, 2016 9:08:41 AM org.apache.jasper.servlet.TldScanner scanJars
mai 12, 2016 9:08:41 AM org.apache.catalina.startup.HostConfig deployDescriptor
INFORMAÇÕES: Deployment of configuration descriptor /etc/tomcat8/Catalina/localhost/examples.xml has finished in 1,158 ms
mai 12, 2016 9:08:41 AM org.apache.catalina.startup.HostConfig deployWAR
INFORMAÇÕES: Deploying web application archive /var/lib/tomcat8/webapps/geonetwork.war
mai 12, 2016 9:08:57 AM org.apache.jasper.servlet.TldScanner scanJars
mai 12, 2016 9:08:57 AM org.apache.catalina.core.ApplicationContext log
INFORMAÇÕES: No Spring WebApplicationInitializer types detected on classpath
2016-05-12 09:09:07,361 DEBUG [geonetwork.databasemigration] - DB Migration / Running 'class org.apache.commons.dbcp.BasicDataSource' after initialization of 'javax.sql.DataSource'.
2016-05-12 09:09:07,392 INFO  [geonetwork.databasemigration] -   - Migration ...
2016-05-12 09:09:07,841 INFO  [geonetwork.databasemigration] -       Webapp   version:3.0.4-0 subversion:SNAPSHOT
2016-05-12 09:09:07,841 INFO  [geonetwork.databasemigration] -       Database version:3.0.4 subversion:0
2016-05-12 09:09:07,842 INFO  [geonetwork.databasemigration] -       Webapp version = Database version, no migration task to apply.
2016-05-12 09:09:22,084 WARN  [org.jzkit.configuration.provider.xml.InMemoryImpl] - Unable to locate resource profiles/geo.xml
2016-05-12 09:09:22,085 WARN  [org.jzkit.configuration.provider.xml.InMemoryImpl] - Unable to locate resource crosswalks/QueryModel/gils.xml
2016-05-12 09:09:22,085 WARN  [org.jzkit.configuration.provider.xml.InMemoryImpl] - Unable to locate resource crosswalks/QueryModel/dc.xml
2016-05-12 09:09:22,085 WARN  [org.jzkit.configuration.provider.xml.InMemoryImpl] - Unable to locate resource crosswalks/QueryModel/rec.xml
2016-05-12 09:09:22,086 WARN  [org.jzkit.configuration.provider.xml.InMemoryImpl] - Unable to locate resource crosswalks/QueryModel/geo.xml
2016-05-12 09:09:22,087 WARN  [org.jzkit.configuration.provider.xml.InMemoryImpl] - Unable to locate resource crosswalks/QueryModel/cql.xml
2016-05-12 09:09:25,289 DEBUG [geonetwork.databasemigration] - DB Migration / Running 'class org.springframework.orm.jpa.JpaTransactionManager' after initialization of 'org.springframework.orm.jpa.JpaTransactionManager'.
2016-05-12 09:09:25,290 INFO  [geonetwork.databasemigration] -   - Migration ...
2016-05-12 09:09:25,300 INFO  [geonetwork.databasemigration] -       Webapp   version:3.0.4-0 subversion:SNAPSHOT
2016-05-12 09:09:25,300 INFO  [geonetwork.databasemigration] -       Database version:3.0.4 subversion:0
2016-05-12 09:09:25,300 INFO  [geonetwork.databasemigration] -       Webapp version = Database version, no migration task to apply.
2016-05-12 09:09:49,075 WARN  [geonetwork.data.directory] -     - Data directory properties is not set. Use geonetwork.dir or geonetwork.dir properties.
2016-05-12 09:09:49,075 WARN  [geonetwork.data.directory] -     - Data directory provided could not be used. Using default location: /var/lib/tomcat8/webapps/geonetwork/WEB-INF/data
2016-05-12 09:09:53,064 WARN  [geonetwork.schemamanager] - WARNING: gco:Record is a global element without a type - assuming a string
2016-05-12 09:09:54,740 WARN  [geonetwork.schemamanager] - WARNING: gco:Record is a global element without a type - assuming a string
2016-05-12 09:09:54,782 WARN  [geonetwork.schemamanager] - WARNING: schema-substitutions.xml has wiped out XSD substitution list for gml:VerticalDatum
2016-05-12 09:09:54,793 WARN  [geonetwork.schemamanager] - WARNING: schema-substitutions.xml has wiped out XSD substitution list for gml:CoordinateSystemAxis
2016-05-12 09:09:54,815 WARN  [geonetwork.schemamanager] - WARNING: schema-substitutions.xml has wiped out XSD substitution list for gml:VerticalCS
2016-05-12 09:09:54,845 WARN  [geonetwork.schemamanager] - WARNING: schema-substitutions.xml has wiped out XSD substitution list for gml:CoordinateSystemAxis
2016-05-12 09:10:00,756 WARN  [geonetwork.schemamanager] - Cannot resolve [http://www.w3.org/2001/03/xml.xsd](http://www.w3.org/2001/03/xml.xsd): will append last component to current path (not sure it will help though!)
2016-05-12 09:10:05,371 WARN  [geonetwork.lucene] - Stopwords file with incorrect ISO 639-2 language as filename: README
mai 12, 2016 9:10:19 AM org.apache.catalina.core.ApplicationContext log
INFORMAÇÕES: Initializing Spring FrameworkServlet 'spring'
mai 12, 2016 9:10:25 AM org.apache.catalina.startup.HostConfig deployWAR
INFORMAÇÕES: Deployment of web application archive /var/lib/tomcat8/webapps/geonetwork.war has finished in 103,848 ms
mai 12, 2016 9:10:25 AM org.apache.catalina.startup.HostConfig deployDirectory
INFORMAÇÕES: Deploying web application directory /var/lib/tomcat8/webapps/ROOT
mai 12, 2016 9:10:26 AM org.apache.jasper.servlet.TldScanner scanJars
mai 12, 2016 9:10:26 AM org.apache.catalina.startup.HostConfig deployDirectory
INFORMAÇÕES: Deployment of web application directory /var/lib/tomcat8/webapps/ROOT has finished in 1,487 ms
mai 12, 2016 9:10:26 AM org.apache.coyote.AbstractProtocol start
INFORMAÇÕES: Starting ProtocolHandler ["http-nio-8080"]
mai 12, 2016 9:10:26 AM org.apache.catalina.startup.Catalina start
INFORMAÇÕES: Server startup in 109860 ms
2016-05-12 09:10:31,991 WARN  [geonetwork.thesaurus] - No thesaurus found for concept scheme [http://geonetwork-opensource.org/inspire-theme](http://geonetwork-opensource.org/inspire-theme) (lang=por)
2016-05-12 09:10:33,644 ERROR [jeeves.service] -    -> exception during transformation for : admin.console
2016-05-12 09:10:33,645 ERROR [jeeves.service] -    ->  (C) stylesheet : /var/lib/tomcat8/webapps/geonetwork/xsl/../xslt/ui-admin/admin.xsl
2016-05-12 09:10:33,646 ERROR [jeeves.service] -    ->  (C) message    : java.io.IOException: Pipe quebrado
2016-05-12 09:10:33,646 ERROR [jeeves.service] -    ->  (C) exception  : ClientAbortException
Error
  org.apache.catalina.connector.ClientAbortException: java.io.IOException: Pipe quebrado
net.sf.saxon.trans.XPathException: org.apache.catalina.connector.ClientAbortException: java.io.IOException: Pipe quebrado
	at net.sf.saxon.event.XMLEmitter.close(XMLEmitter.java:264)
	at net.sf.saxon.event.ProxyReceiver.close(ProxyReceiver.java:90)
	at net.sf.saxon.event.ComplexContentOutputter.close(ComplexContentOutputter.java:507)
	at net.sf.saxon.Controller.transformDocument(Controller.java:1848)
	at net.sf.saxon.Controller.transform(Controller.java:1621)
	at org.fao.geonet.utils.Xml.transform(Xml.java:611)
	at org.fao.geonet.utils.Xml.transform(Xml.java:425)
	at jeeves.server.dispatchers.ServiceManager.dispatchError(ServiceManager.java:873)
	at jeeves.server.dispatchers.ServiceManager.handleError(ServiceManager.java:550)
	at jeeves.server.dispatchers.ServiceManager.dispatch(ServiceManager.java:498)
	at jeeves.server.dispatchers.ServiceManager.dispatch(ServiceManager.java:384)
	at jeeves.server.JeevesEngine.dispatch(JeevesEngine.java:609)
	at org.fao.geonet.services.main.GenericController.dispatch(GenericController.java:106)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
	at java.lang.reflect.Method.invoke(Method.java:498)
	at org.springframework.web.method.support.InvocableHandlerMethod.invoke(InvocableHandlerMethod.java:219)
	at org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:132)
	at org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:104)
	at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandleMethod(RequestMappingHandlerAdapter.java:745)
	at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:686)
	at org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:80)
	at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:925)
	at jeeves.config.springutil.JeevesDispatcherServlet.access$001(JeevesDispatcherServlet.java:17)
	at jeeves.config.springutil.JeevesDispatcherServlet$1.doInTransaction(JeevesDispatcherServlet.java:30)
	at jeeves.config.springutil.JeevesDispatcherServlet$1.doInTransaction(JeevesDispatcherServlet.java:27)
	at jeeves.transaction.TransactionManager.runInTransaction(TransactionManager.java:63)
	at jeeves.config.springutil.JeevesDispatcherServlet.doDispatch(JeevesDispatcherServlet.java:24)
	at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:856)
	at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:936)
	at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:827)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:622)
	at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:812)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:292)
	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:207)
	at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:240)
	at org.fao.geonet.monitor.webapp.WebappMetricsFilter.doFilter(WebappMetricsFilter.java:96)
	at org.fao.geonet.monitor.webapp.MetricsRegistryInitializerFilter.doFilter(MetricsRegistryInitializerFilter.java:31)
	at org.tuckey.web.filters.urlrewrite.RuleChain.handleRewrite(RuleChain.java:176)
	at org.tuckey.web.filters.urlrewrite.RuleChain.doRules(RuleChain.java:145)
	at org.tuckey.web.filters.urlrewrite.UrlRewriter.processRequest(UrlRewriter.java:92)
	at org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:381)
	at org.geonetwork.http.SessionTimeoutCookieFilter.doFilter(SessionTimeoutCookieFilter.java:56)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:118)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:84)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:342)
	at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
	at org.springframework.security.web.session.SessionManagementFilter.doFilter(SessionManagementFilter.java:103)
	at org.springframework.security.web.authentication.AnonymousAuthenticationFilter.doFilter(AnonymousAuthenticationFilter.java:113)
	at org.springframework.security.web.savedrequest.RequestCacheAwareFilter.doFilter(RequestCacheAwareFilter.java:45)
	at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:183)
	at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
	at jeeves.config.springutil.PassthroughFilter.doFilter(PassthroughFilter.java:26)
	at jeeves.config.springutil.MultiNodeAuthenticationFilter.doFilter(MultiNodeAuthenticationFilter.java:98)
	at org.springframework.security.web.authentication.logout.LogoutFilter.doFilter(LogoutFilter.java:105)
	at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
	at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:192)
	at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:160)
	at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:343)
	at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:260)
	at jeeves.config.springutil.JeevesDelegatingFilterProxy.doFilter(JeevesDelegatingFilterProxy.java:64)
	at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:88)
	at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:106)
	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:141)
	at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79)
	at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:616)
	at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:88)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:522)
	at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1095)
	at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:672)
	at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1500)
	at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.run(NioEndpoint.java:1456)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
	at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
	at java.lang.Thread.run(Thread.java:745)
Caused by: org.apache.catalina.connector.ClientAbortException: java.io.IOException: Pipe quebrado
	at org.apache.catalina.connector.OutputBuffer.realWriteBytes(OutputBuffer.java:393)
	at org.apache.tomcat.util.buf.ByteChunk.flushBuffer(ByteChunk.java:426)
	at org.apache.catalina.connector.OutputBuffer.doFlush(OutputBuffer.java:342)
	at org.apache.catalina.connector.OutputBuffer.flush(OutputBuffer.java:317)
	at org.apache.catalina.connector.CoyoteOutputStream.flush(CoyoteOutputStream.java:110)
	at org.springframework.security.web.context.SaveContextOnUpdateOrErrorResponseWrapper$SaveContextServletOutputStream.flush(SaveContextOnUpdateOrErrorResponseWrapper.java:354)
	at sun.nio.cs.StreamEncoder.implFlush(StreamEncoder.java:297)
	at sun.nio.cs.StreamEncoder.flush(StreamEncoder.java:141)
	at java.io.OutputStreamWriter.flush(OutputStreamWriter.java:229)
	at java.io.BufferedWriter.flush(BufferedWriter.java:254)
	at net.sf.saxon.event.XMLEmitter.close(XMLEmitter.java:261)
	... 104 more
Caused by: java.io.IOException: Pipe quebrado
	at sun.nio.ch.FileDispatcherImpl.write0(Native Method)
	at sun.nio.ch.SocketDispatcher.write(SocketDispatcher.java:47)
	at sun.nio.ch.IOUtil.writeFromNativeBuffer(IOUtil.java:93)
	at sun.nio.ch.IOUtil.write(IOUtil.java:65)
	at sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:471)
	at org.apache.tomcat.util.net.NioChannel.write(NioChannel.java:124)
	at org.apache.tomcat.util.net.NioBlockingSelector.write(NioBlockingSelector.java:101)
	at org.apache.tomcat.util.net.NioSelectorPool.write(NioSelectorPool.java:172)
	at org.apache.coyote.http11.InternalNioOutputBuffer.writeToSocket(InternalNioOutputBuffer.java:139)
	at org.apache.coyote.http11.InternalNioOutputBuffer.flushBuffer(InternalNioOutputBuffer.java:244)
	at org.apache.coyote.http11.InternalNioOutputBuffer.addToBB(InternalNioOutputBuffer.java:189)
	at org.apache.coyote.http11.InternalNioOutputBuffer.access$000(InternalNioOutputBuffer.java:41)
	at org.apache.coyote.http11.InternalNioOutputBuffer$SocketOutputBuffer.doWrite(InternalNioOutputBuffer.java:320)
	at org.apache.coyote.http11.filters.ChunkedOutputFilter.doWrite(ChunkedOutputFilter.java:116)
	at org.apache.coyote.http11.AbstractOutputBuffer.doWrite(AbstractOutputBuffer.java:256)
	at org.apache.coyote.Response.doWrite(Response.java:501)
	at org.apache.catalina.connector.OutputBuffer.realWriteBytes(OutputBuffer.java:388)
	... 114 more
<details class='elided'>
<summary title='Show trimmed content'>&#183;&#183;&#183;</summary>
2016-05-12 3:14 GMT-03:00 María Arias de Reyna <[delawen@anonymised.com](mailto:delawen@anonymised.com)>:
> Hi,
> Regards,
> María.
> On Thu, May 12, 2016 at 4:14 AM, Idélcio Filho <[isafilho@anonymised.com](mailto:isafilho@anonymised.com)> wrote:
> > Dear,
> > almost empty page .
> > [https://ad.doubleclick.net/ddm/clk/304595813;131938128;j](https://ad.doubleclick.net/ddm/clk/304595813;131938128;j)
> > _______________________________________________
> > [GeoNetwork-devel@lists.sourceforge.net](mailto:GeoNetwork-devel@lists.sourceforge.net)
> > [https://lists.sourceforge.net/lists/listinfo/geonetwork-devel](https://lists.sourceforge.net/lists/listinfo/geonetwork-devel)
> > [http://sourceforge.net/projects/geonetwork](http://sourceforge.net/projects/geonetwork)
</details>
