[GeoNetwork-devel] Elasticsearch upgrade version
Hi Jose and Francois,
I see in the last PSC meeting report that you plan to work on “for ElasticClient client code upgrade to support latest ElasticClient versions.” ?
What is the status of this? We have discussed that in Bolsena but without any real conclusion.
It’s a big move/engagement to update Elasticsearch to version 8 if it’s what you mean.
Could please develop this statement a bit.
Thanks a lot !
This is Florent Gravin's card. Their email is florent.gravin@anonymised.com
Hi Florent
Geonetwork is using the Elasticsearch high level rest client, this component is deprecated and the code should be updated to use Elasticsearch Java API Client.
Checking the documentation, seems it’s possible to use Elasticsearch high level rest client still in Elasticsearch 8, using the compatibility mode: https://www.elastic.co/guide/en/elasticsearch/client/java-rest/current/java-rest-high-compatibility.html
So this can be a short-term solution. In any case, would be good to work to update the code to use Elasticsearch Java API Client. And for sure, should be tested GeoNetwork with Elasticsearch 8 to make sure no additional changes are required.
Jose García
Jose Garcia
E-mail: jose.garcia@anonymised.com
https://www.geocat.net
Veenderweg 13
6721 WD Bennekom
The Netherlands
Tel: +31318416664
---- On Wed, 11 Oct 2023 18:05:35 +0200 Florent Gravin florent.gravin@anonymised.com wrote —
Thanks a lot !
Hi Jose, thanks for the update.
So what I’ve read is that 7.16.x is eol and 7.17.x is eol when ES 9 comes out.
GN is actually version 7.15.1
The Elasticsearch high level rest client is deprecated from ES 7.15.0, but still working for versions 7.1+
What version of ES do you plan to move to ? 7.17+ or 8.x ?
Thanks for the information !
Best
Hi Florent
There is a PR https://github.com/geonetwork/core-geonetwork/pull/7368 to update to version 7.17.13, but haven’t got time to try it.
Jose García
Jose Garcia
Veenderweg 13
6721 WD Bennekom
The Netherlands
Tel: +31318416664
---- On Fri, 13 Oct 2023 14:33:57 +0200 Florent Gravin florent.gravin@anonymised.com wrote —
Best
On Thu, Oct 12, 2023 at 9:43 AM Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi Florent
Jose García
Jose Garcia
Veenderweg 13
6721 WD Bennekom
The Netherlands
Tel: +31318416664
---- On Wed, 11 Oct 2023 18:05:35 +0200 Florent Gravin <florent.gravin@anonymised.com> wrote —
Thanks a lot !
