[GeoNetwork-devel] Error creating new config-editor view (Geonetwork 3.x.x)
Hello again,
In my previous post I sent the logs whole file but the message hasn’t been published in this list (because of the file size).
For creating a custom editor view, I copied the ‘default’ view and gave it a custom name (declaring it in the corresponding schema strings.xml file). Anybody knows if there exist any issue or bug in Geonetwork version 3 related to this feature? Have you got any custom editor view working?
Once Tomcat is restarted, the editor view panel is not working and the following error is shown:
2018-01-25 09:14:51,678 ERROR [jeeves] - Error occurred within a transaction
; SystemID: file:///C:/apache-tomcat-8.5.9/temp/0-geonetwork/WEB-INF/data/config/schema_plugins/iso19139/layout/layout.xsl; Line#: 64; Column#: -1
net.sf.saxon.trans.XPathException: A sequence of more than one item is not allowed as the first argument of gn-fn-metadata:isFieldFlatModeException() (, )
at net.sf.saxon.expr.Expression.typeError(Expression.java:981)
at net.sf.saxon.expr.CardinalityChecker.evaluateItem(CardinalityChecker.java:270)
at net.sf.saxon.expr.ExpressionTool.evaluate(ExpressionTool.java:296)
at net.sf.saxon.expr.UserFunctionCall.evaluateArguments(UserFunctionCall.java:486)
at net.sf.saxon.expr.UserFunctionCall.callFunction(UserFunctionCall.java:412)
at net.sf.saxon.expr.UserFunctionCall.iterate(UserFunctionCall.java:384)
at net.sf.saxon.expr.Expression.effectiveBooleanValue(Expression.java:421)
at net.sf.saxon.expr.BooleanExpression.effectiveBooleanValue(BooleanExpression.java:185)
at net.sf.saxon.instruct.Choose.processLeavingTail(Choose.java:679)
at net.sf.saxon.expr.LetExpression.processLeavingTail(LetExpression.java:557)
at net.sf.saxon.instruct.Choose.processLeavingTail(Choose.java:686)
at net.sf.saxon.instruct.Block.processLeavingTail(Block.java:556)
at net.sf.saxon.instruct.Template.applyLeavingTail(Template.java:203)
at net.sf.saxon.instruct.ApplyTemplates.applyTemplates(ApplyTemplates.java:345)
at net.sf.saxon.instruct.ApplyTemplates$ApplyTemplatesPackage.processLeavingTail(ApplyTemplates.java:527)
at net.sf.saxon.instruct.ApplyTemplates.applyTemplates(ApplyTemplates.java:317)
at net.sf.saxon.instruct.ApplyTemplates.apply(ApplyTemplates.java:210)
at net.sf.saxon.instruct.ApplyTemplates.process(ApplyTemplates.java:170)
at net.sf.saxon.instruct.DocumentInstr.evaluateItem(DocumentInstr.java:278)
at net.sf.saxon.instruct.GeneralVariable.getSelectValue(GeneralVariable.java:374)
at net.sf.saxon.instruct.Instruction.assembleParams(Instruction.java:147)
at net.sf.saxon.instruct.CallTemplate.processLeavingTail(CallTemplate.java:291)
at net.sf.saxon.instruct.CallTemplate.process(CallTemplate.java:259)
at net.sf.saxon.instruct.CallTemplate.processLeavingTail(CallTemplate.java:281)
at net.sf.saxon.instruct.Instruction.process(Instruction.java:93)
at net.sf.saxon.expr.LetExpression.process(LetExpression.java:378)
at net.sf.saxon.instruct.ForEach.processLeavingTail(ForEach.java:321)
at net.sf.saxon.instruct.ApplyTemplates.processLeavingTail(ApplyTemplates.java:174)
at net.sf.saxon.instruct.ElementCreator.processLeavingTail(ElementCreator.java:296)
at net.sf.saxon.Controller.transformDocument(Controller.java:1807)
at net.sf.saxon.Controller.transform(Controller.java:1621)
at org.fao.geonet.utils.Xml.transform(Xml.java:486)
at org.fao.geonet.utils.Xml.transform(Xml.java:358)
at org.fao.geonet.api.records.editing.MetadataEditingApi.buildEditorForm(MetadataEditingApi.java:698)
at org.fao.geonet.api.records.editing.MetadataEditingApi.startEditing(MetadataEditingApi.java:162)
at org.fao.geonet.api.records.editing.MetadataEditingApi$$FastClassBySpringCGLIB$$363e745.invoke()
at org.springframework.cglib.proxy.MethodProxy.invoke(MethodProxy.java:204)
at org.springframework.aop.framework.CglibAopProxy$CglibMethodInvocation.invokeJoinpoint(CglibAopProxy.java:720)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:157)
at org.springframework.security.access.intercept.aopalliance.MethodSecurityInterceptor.invoke(MethodSecurityInterceptor.java:64)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:179)
at org.springframework.aop.framework.CglibAopProxy$DynamicAdvisedInterceptor.intercept(CglibAopProxy.java:655)
at org.fao.geonet.api.records.editing.MetadataEditingApi$$EnhancerBySpringCGLIB$$4b483f04.startEditing()
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.springframework.web.method.support.InvocableHandlerMethod.doInvoke(InvocableHandlerMethod.java:222)
at org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:137)
at org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:110)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:814)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:737)
at org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:85)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:959)
at jeeves.config.springutil.JeevesDispatcherServlet.access$001(JeevesDispatcherServlet.java:41)
at jeeves.config.springutil.JeevesDispatcherServlet$1.doInTransaction(JeevesDispatcherServlet.java:54)
at jeeves.config.springutil.JeevesDispatcherServlet$1.doInTransaction(JeevesDispatcherServlet.java:51)
at jeeves.transaction.TransactionManager.runInTransaction(TransactionManager.java:73)
at jeeves.config.springutil.JeevesDispatcherServlet.doDispatch(JeevesDispatcherServlet.java:48)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:893)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:969)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:860)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:622)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:845)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:230)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:165)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:192)
at org.fao.geonet.monitor.webapp.WebappMetricsFilter.doFilter(WebappMetricsFilter.java:121)
at org.fao.geonet.monitor.webapp.MetricsRegistryInitializerFilter.doFilter(MetricsRegistryInitializerFilter.java:58)
at org.tuckey.web.filters.urlrewrite.RuleChain.handleRewrite(RuleChain.java:176)
at org.tuckey.web.filters.urlrewrite.RuleChain.doRules(RuleChain.java:145)
at org.tuckey.web.filters.urlrewrite.UrlRewriter.processRequest(UrlRewriter.java:92)
at org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:381)
at org.geonetwork.http.SessionTimeoutCookieFilter.doFilter(SessionTimeoutCookieFilter.java:89)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:118)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:84)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:342)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.springframework.security.web.session.SessionManagementFilter.doFilter(SessionManagementFilter.java:103)
at org.springframework.security.web.authentication.AnonymousAuthenticationFilter.doFilter(AnonymousAuthenticationFilter.java:113)
at org.springframework.security.web.savedrequest.RequestCacheAwareFilter.doFilter(RequestCacheAwareFilter.java:45)
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:199)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
at jeeves.config.springutil.PassthroughFilter.doFilter(PassthroughFilter.java:50)
at jeeves.config.springutil.MultiNodeAuthenticationFilter.doFilter(MultiNodeAuthenticationFilter.java:122)
at org.springframework.security.web.authentication.logout.LogoutFilter.doFilter(LogoutFilter.java:110)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:192)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:160)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262)
at jeeves.config.springutil.JeevesDelegatingFilterProxy.doFilter(JeevesDelegatingFilterProxy.java:104)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:121)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:198)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:96)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:140)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79)
at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:624)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:87)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:349)
at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:783)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:66)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:789)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1437)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:748)
Any kind of help would be appreciate.
Best regards,
Amaia Martínez
Defining a custom editor view definitely works in Geonetwork 3.x. From your error it seems there are two views with the same name defined. Could you maybe show us the content of config-editor.xml?
(attachments)
On Wed, Jan 31, 2018 at 8:10 AM, Amaya Martínez Echeverría <amartinez@anonymised.com> wrote:
Hello again,
Best regards,
Amaia Martínez
AVISO SOBRE CONFIDENCIALIDAD: La información incluida en este mensaje es CONFIDENCIAL y de uso EXCLUSIVO a su FINALIDAD. Su posterior divulgación será responsabilidad de quien la realice
GeoNetwork-devel mailing list
GeoNetwork-devel@…537…sourceforge.net
camptocamp
INNOVATIVE SOLUTIONS
BY OPEN SOURCE EXPERTS
Olivier Guyot
Geospatial Developer
+33 4 58 48 20 28
