Buenos días, por favor su ayuda, tengo un problema con Geonetwork 3.12 cuando hago un harvesting de un servicio WMS o WFS.
* Solo importa 1 registro o metadato y el resto presentan el siguiente error:
Good morning, please help, I have a problem with Geonetwork 3.12 when I harvest a WMS or WFS service.
* It only imports 1 record or metadata and the rest present the following error:
2021-08-23T16:00:59,141-0500 INFO [wfs_regional] - Starting harvesting of wfs_servicio
2021-08-23T16:00:59,159-0500 INFO [wfs_regional] - Started harvesting from node : wfs_servicio (OgcWxSHarvester)
2021-08-23T16:00:59,162-0500 INFO [wfs_regional] - Retrieving remote metadata information for : wfs_servicio
2021-08-23T16:00:59,412-0500 INFO [wfs_regional] - - Number of layers, featureTypes, Coverages or process found : **55**
2021-08-23T16:00:59,412-0500 INFO [wfs_regional] - - <b>Loading layer: srv:aeropuerto with UUID dbaf2fcbbe6a5cd02a883f60e29eb5fba4a1c05a (hash of capabilities URL + layer name).
2021-08-23T16:00:59,434-0500 WARN [wfs_regional] - - Failed to load metadata document for layer 'srv:aeropuerto'. Error is: 'For input string: ""',</b>
Hi, not sure it is related but sounds like https://github.com/geonetwork/core-geonetwork/pull/5733
Maybe you could backport the change in your version and see if it works?
Francois
Le jeu. 26 août 2021 à 17:21, Carlos Parra via GeoNetwork-devel <geonetwork-devel@lists.sourceforge.net> a écrit :
GeoNetwork-devel mailing list
