[GeoNetwork-devel] Error while Building GeoNetwork using Maven,
I am doing a setup of GeoNetwork development environment by using the
instructions in the below URL
http://geonetwork-opensource.org/stable/developers/development/index.html
at the step Build GeoNetwork
$ mvn clean install
getting the following exceptions while building the Jeeves, Please help me
to resolve the issue
[INFO]
[INFO] Building Jeeves modules 2.7.0-SNAPSHOT
[INFO]
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ jeeves ---
[INFO] Deleting D:\GeoNetwork_SVN\jeeves\target
[INFO]
[INFO] --- maven-resources-plugin:2.4.3:resources (default-resources) @
jeeves ---
[INFO] skip non existing resourceDirectory
D:\GeoNetwork_SVN\jeeves\src\main\resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ jeeves
[INFO] Compiling 100 source files to D:\GeoNetwork_SVN\jeeves\target\classes
[INFO] -------------------------------------------------------------
[ERROR] COMPILATION ERROR :
[ERROR]
\GeoNetwork_SVN\jeeves\src\main\java\jeeves\utils\XmlElementReader.java:[35,24]
package javax.xml.stream do
es not exist
[ERROR]
\GeoNetwork_SVN\jeeves\src\main\java\jeeves\utils\XmlElementReader.java:[36,24]
es not exist
[ERROR]
\GeoNetwork_SVN\jeeves\src\main\java\jeeves\utils\XmlElementReader.java:[37,24]
es not exist
[ERROR]
\GeoNetwork_SVN\jeeves\src\main\java\jeeves\utils\XmlElementReader.java:[38,24]
es not exist
[ERROR]
\GeoNetwork_SVN\jeeves\src\main\java\jeeves\utils\XmlElementReader.java:[39,24]
es not exist
[ERROR]
\GeoNetwork_SVN\jeeves\src\main\java\jeeves\utils\XmlElementReader.java:[40,31]
package javax.xml.stream.ev
ents does not exist
[ERROR]
\GeoNetwork_SVN\jeeves\src\main\java\jeeves\utils\XmlElementReader.java:[41,31]
ents does not exist
[ERROR]
\GeoNetwork_SVN\jeeves\src\main\java\jeeves\utils\XmlElementReader.java:[42,31]
ents does not exist
[ERROR]
\GeoNetwork_SVN\jeeves\src\main\java\jeeves\utils\XmlElementReader.java:[43,31]
ents does not exist
[ERROR]
\GeoNetwork_SVN\jeeves\src\main\java\jeeves\utils\XmlElementReader.java:[62,16]
cannot find symbol
symbol : class XMLEventReader
[ERROR]
\GeoNetwork_SVN\jeeves\src\main\java\jeeves\utils\XmlElementReader.java:[63,16]
cannot find symbol
[ERROR]
\GeoNetwork_SVN\jeeves\src\main\java\jeeves\utils\XmlElementReader.java:[76,109]
cannot find symbol
symbol : class XMLStreamException
[ERROR]
\GeoNetwork_SVN\jeeves\src\main\java\jeeves\utils\XmlElementReader.java:[76,129]
cannot find symbol
symbol : class FactoryConfigurationError
[ERROR]
\GeoNetwork_SVN\jeeves\src\main\java\jeeves\utils\XmlElementReader.java:[197,38]
cannot find symbol
[ERROR]
\GeoNetwork_SVN\jeeves\src\main\java\jeeves\utils\XmlElementReader.java:[77,30]
cannot find symbol
symbol : variable XMLInputFactory
[ERROR]
\GeoNetwork_SVN\jeeves\src\main\java\jeeves\utils\XmlElementReader.java:[125,40]
cannot find symbol
[ERROR]
\GeoNetwork_SVN\jeeves\src\main\java\jeeves\utils\XmlElementReader.java:[128,51]
cannot find symbol
symbol : variable XMLStreamConstants
[ERROR]
\GeoNetwork_SVN\jeeves\src\main\java\jeeves\utils\XmlElementReader.java:[130,58]
cannot find symbol
[ERROR]
\GeoNetwork_SVN\jeeves\src\main\java\jeeves\utils\XmlElementReader.java:[135,59]
cannot find symbol
symbol : variable XMLEvent
[ERROR]
\GeoNetwork_SVN\jeeves\src\main\java\jeeves\utils\XmlElementReader.java:[152,24]
cannot find symbol
[ERROR]
\GeoNetwork_SVN\jeeves\src\main\java\jeeves\utils\XmlElementReader.java:[154,46]
cannot find symbol
[ERROR]
\GeoNetwork_SVN\jeeves\src\main\java\jeeves\utils\XmlElementReader.java:[157,25]
cannot find symbol
[ERROR]
\GeoNetwork_SVN\jeeves\src\main\java\jeeves\utils\XmlElementReader.java:[161,25]
cannot find symbol
[ERROR]
\GeoNetwork_SVN\jeeves\src\main\java\jeeves\utils\XmlElementReader.java:[162,25]
cannot find symbol
[ERROR]
\GeoNetwork_SVN\jeeves\src\main\java\jeeves\utils\XmlElementReader.java:[166,25]
cannot find symbol
[ERROR]
\GeoNetwork_SVN\jeeves\src\main\java\jeeves\utils\XmlElementReader.java:[170,25]
cannot find symbol
[ERROR]
\GeoNetwork_SVN\jeeves\src\main\java\jeeves\utils\XmlElementReader.java:[171,24]
cannot find symbol
symbol : class EntityReference
[ERROR]
\GeoNetwork_SVN\jeeves\src\main\java\jeeves\utils\XmlElementReader.java:[171,46]
cannot find symbol
[ERROR]
\GeoNetwork_SVN\jeeves\src\main\java\jeeves\utils\XmlElementReader.java:[175,25]
cannot find symbol
[ERROR]
\GeoNetwork_SVN\jeeves\src\main\java\jeeves\utils\XmlElementReader.java:[176,47]
vents does not exist
[ERROR]
\GeoNetwork_SVN\jeeves\src\main\java\jeeves\utils\XmlElementReader.java:[176,99]
[ERROR]
\GeoNetwork_SVN\jeeves\src\main\java\jeeves\utils\XmlElementReader.java:[180,25]
cannot find symbol
[ERROR]
\GeoNetwork_SVN\jeeves\src\main\java\jeeves\utils\XmlElementReader.java:[186,32]
cannot find symbol
[ERROR]
\GeoNetwork_SVN\jeeves\src\main\java\jeeves\utils\XmlElementReader.java:[214,21]
cannot find symbol
symbol : class Namespace
[ERROR]
\GeoNetwork_SVN\jeeves\src\main\java\jeeves\utils\XmlElementReader.java:[217,16]
cannot find symbol
[ERROR]
\GeoNetwork_SVN\jeeves\src\main\java\jeeves\utils\XmlElementReader.java:[228,21]
cannot find symbol
symbol : class Attribute
[ERROR]
\GeoNetwork_SVN\jeeves\src\main\java\jeeves\utils\XmlElementReader.java:[231,16]
cannot find symbol
[INFO] 37 errors
[INFO]
[INFO] Reactor Summary:
[INFO]
[INFO] GeoNetwork opensource ............................. SUCCESS [1.391s]
[INFO] Caching xslt module ............................... SUCCESS [4.453s]
[INFO] Jeeves modules .................................... FAILURE [6.562s]
[INFO] Oaipmh modules .................................... SKIPPED
[INFO] ArcSDE module (dummy-api) ......................... SKIPPED
[INFO] GeoNetwork Web module ............................. SKIPPED
[INFO] GeoServer module .................................. SKIPPED
[INFO] Gast module ....................................... SKIPPED
[INFO] GeoNetwork Integration Tests ...................... SKIPPED
[INFO]
[INFO] BUILD FAILURE
[INFO]
[INFO] Total time: 12.922s
[INFO] Finished at: Tue May 31 10:14:04 IST 2011
[INFO] Final Memory: 6M/19M
[INFO]
[ERROR] Failed to execute goal
org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile
(default-compile) on pr
oject jeeves: Compilation failure: Compilation failure:
[ERROR]
es not exist
[ERROR]
es not exist
[ERROR]
es not exist
[ERROR]
es not exist
[ERROR]
es not exist
[ERROR]
ents does not exist
[ERROR]
ents does not exist
[ERROR]
ents does not exist
[ERROR]
ents does not exist
[ERROR]
cannot find symbol
[ERROR] symbol : class XMLEventReader
[ERROR] location: class jeeves.utils.XmlElementReader
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR] symbol : class XMLStreamException
[ERROR]
cannot find symbol
[ERROR] symbol : class FactoryConfigurationError
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR] symbol : variable XMLInputFactory
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR] symbol : variable XMLStreamConstants
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR] symbol : variable XMLEvent
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR] symbol : class EntityReference
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
[ERROR]
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR] symbol : class Namespace
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR] symbol : class Attribute
[ERROR]
cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e
switch.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please
read the following articles:
[ERROR] [Help 1]
http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureException
[ERROR]
[ERROR] After correcting the problems, you can resume the build with the
command
[ERROR] mvn <goals> -rf :jeeves
Thanks in Advance,
Praveen Kumar A
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Error-while-Building-GeoNetwork-using-Maven-tp6421406p6421406.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
hi,
it seems you’re missing something in your CLASSPATH. Google this problem and you’ll see you’re not the only one with the problem “package javax.xml.stream does not exist”.
See e.g. http://www.thatsjava.com/java-essentials/36377/ for clues ?
kind regards
Heikki Doeleman
On Tue, May 31, 2011 at 6:58 AM, Praveen <Praveenkumar.Anugandula@anonymised.com752…> wrote:
$ mvn clean install
[INFO]
[INFO]
[INFO]
[INFO] — maven-clean-plugin:2.4.1:clean (default-clean) @ jeeves —
[INFO]
[INFO] — maven-resources-plugin:2.4.3:resources (default-resources) @
jeeves —
[INFO] Using ‘UTF-8’ encoding to copy filtered resources.
[INFO]
[INFO] — maven-compiler-plugin:2.3.2:compile (default-compile) @ jeeves
[ERROR]
es not exist
[ERROR]
es not exist
[ERROR]
es not exist
[ERROR]
es not exist
[ERROR]
es not exist
[ERROR]
ents does not exist
[ERROR]
ents does not exist
[ERROR]
ents does not exist
[ERROR]
ents does not exist
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
[ERROR]
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[INFO] 37 errors
[INFO]
[INFO]
[INFO] GeoNetwork opensource … SUCCESS [1.391s]
[INFO] Caching xslt module … SUCCESS [4.453s]
[INFO] Jeeves modules … FAILURE [6.562s]
[INFO] Oaipmh modules … SKIPPED
[INFO] ArcSDE module (dummy-api) … SKIPPED
[INFO] GeoNetwork Web module … SKIPPED
[INFO] GeoServer module … SKIPPED
[INFO] Gast module … SKIPPED
[INFO] GeoNetwork Integration Tests … SKIPPED
[INFO]
[INFO]
[INFO]
[ERROR]
es not exist
[ERROR]
es not exist
[ERROR]
es not exist
[ERROR]
es not exist
[ERROR]
es not exist
[ERROR]
ents does not exist
[ERROR]
ents does not exist
[ERROR]
ents does not exist
[ERROR]
ents does not exist
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
[ERROR]
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR]
cannot find symbol
[ERROR] → [Help 1]
[ERROR]
switch.
[ERROR]
[ERROR] [Help 1]
[ERROR]
command
[ERROR] mvn -rf :jeeves
Thanks in Advance,
Praveen Kumar A
Simplify data backup and recovery for your virtual environment with vRanger.
Installation’s a snap, and flexible recovery options mean your data is safe,
secure and there when you need it. Data protection magic?
Nope - It’s vRanger. Get your free trial download today.
http://p.sf.net/sfu/quest-sfdev2dev
GeoNetwork-devel mailing list
