Hi everybody,
I work on a Geonetwork v2.10 HTML5UI.
I need a big support on how to set up the faceted search panel. I can not find detailed information on how to change categories, add items and link this item to a field of my metadata template.
If some one knows where documentation is available or explain the process to set up this part of the GeoNetwork, it would be great !
Thanks for your answer !
Sylvie de Laborderie
GIS Officer
CartONG
+33 7 87 05 43 92
+33 4 79 26 28 82
www.cartong.org
I don’t know the html 5 UI but on the server side the configuration is in the config-summary.xml file. I think by default the facets are obtained by doing a “hits” search. So you only have to be concerned about the “hits” summary configuration.
Jesse
On Fri, Feb 28, 2014 at 6:10 PM, Sylvie De Laborderie <s_delaborderie@anonymised.com> wrote:
Hi everybody,
GIS Officer
CartONG
+33 7 87 05 43 92
+33 4 79 26 28 82
www.cartong.org
Flow-based real-time traffic analytics software. Cisco certified tool.
Monitor traffic, SLAs, QoS, Medianet, WAAS etc. with NetFlow Analyzer
Customize your own dashboards, set traffic alerts and generate reports.
Network behavioral analysis & security monitoring. All-in-one tool.
http://pubads.g.doubleclick.net/gampad/clk?id=126839071&iu=/4140/ostg.clktrk
GeoNetwork-devel mailing list
Also need to update GeoNetwork.Settings.facetListConfig in the Settings.js
file and rebuild index from the Administration page.
Some documentation:
http://geonetwork-opensource.org/manuals/2.10.3/eng/widgets/lib/web-client/jst/GeoNetwork/widgets/FacetsPanel.html
I also found this helpful
http://trac.osgeo.org/geonetwork/wiki/NarrowYourSearchWidget.
I hope this helps.
Shiree
View this message in context: http://osgeo-org.1560.x6.nabble.com/Faceted-Search-Panel-tp5106684p5127944.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
