Dear All, José and Maria,
In a EU project (H2020 Odyssea) that we are using Geonetwork, docker is a requirement to deploy the several components where Geonetwork is one of them. This is done using an empty customized CentOS docker image where, using a DOCKER file the JAVA, TOMCAT and Geonetwork are configured to be executed.
Finally a docker-compose file is used to orchestrate the several docker images (being the Geonetwork one of them).
We’ve managed to do the above (with empty CentOS image) using an externalized postgres database (on the host filesystem) in order not to lose (persist) the information. This is ok.
The problem is that once you configure the database access an then latter you down the docker-compose (stop and remove the images) the configuration is lost (not the db itself as it is mounted externally).
So, as you may imagine, we would like to persist the configuration of Geonetwork outside the docker image, on the persistent storage of the host, for example.
It is possible to do this ?
Can you please assist us ?
Please let me know ASAP.
Thank you for your time and best regards,
Carlos Figueiredo Technical Manager / Senior System Analyst |
Tel: +351.212945900 Mobile: +351. 937 673 523 Fax: +351.212945999 |
Rua Calvet Magalhães, 245 2770-153 Paço de Arcos · Portugal |
A informação contida neste e-mail e quaisquer documentos anexos são propriedade da EDISOFT e poderão ser confidenciais. Se não for o destinatário pretendido, por favor, comunique-nos de imediato, enviando-nos esta mensagem de volta e destruindo-a em seguida. Fica desde já advertido de que é estritamente proibida qualquer revisão, divulgação, distribuição, cópia ou qualquer outra utilização deste e-mail.
The information contained in this e-mail and any attachments are the property of EDISOFT and may be confidential. If you are not the intended recipient, please notify us immediately, send this message back to us and destroy it. You are hereby notified that any review, dissemination, distribution, copying or otherwise use of this e-mail is strictly prohibited
