I have rolled out 3.0.1 via war
Running within tomcat 8.0
Printing still doesn’t work within tomcat 8
Does the latest 3.0.1 war file contain the fix for the printing issue within tomcat 8?
What do I need to do to get this working?
Yes, the last 3.0.1 version should contains the fix, it includes the last mapfishprint dependencies (2.1.1).
It have been tested successfully on some instances.
What error do you have ?
On Wed, Jul 15, 2015 at 4:20 AM, Peter <upploadds@anonymised.com> wrote:
Printing still doesn’t work within tomcat 8Does the latest 3.0.1 war file contain the fix for the printing issue within tomcat 8?
Don’t Limit Your Business. Reach for the Cloud.
GigeNET’s Cloud Solutions provide you with the tools and support that
you need to offload your IT needs and focus on growing your business.
Configured For All Businesses. Start Your Cloud Today.
https://www.gigenetcloud.com/
GeoNetwork-devel mailing list
camptocamp
INNOVATIVE SOLUTIONS
BY OPEN SOURCE EXPERTS
Florent Gravin
0479444492
I just rolled out the war in tomcat 7 and it seems to work ok. Printing takes awhile to produce the pdf so maybe I didn’t wait long enough previously.
I might try again in tomcat 8 and see if it was just slow.
I’ll let you know.
On Wed, Jul 15, 2015 at 4:20 AM, Peter <upploadds@anonymised.com…> wrote:
camptocamp
Florent Gravin
0479444492
Ok so after testing the print functions in both tomcat 8 and tomcat 7.
In tomcat 8 print doesn’t function
In tomcat 7 print works but only if you choose thumbnail.
In tomcat 8 the templates do not populate.
I think I will stick with tomcat 7 for the moment.
camptocamp
Florent Gravin
0479444492
