Hi
I have some questions about the date search fields in the GeoNetwork 3.0:
- At the top are displayed in a bar graphic several years, but no indication of what is filtering this section or what represents the bar size.
When selecting a year, the query searches for the createDateYear lucene field, so I guess the size of the bar represents the total metadata with date type=creation for that year.
I think would be good to add some label and tooltip for this section.
- There’s 2 date sections below:
Resources created at, this queries the createDate lucene field, metadata with date type=creation
Records created at, this queries the changeDate lucene field. The label doesn’t seem very clear.
At least for me, is not very clear when I access the form (without knowing the internal fields in the query) what is the difference between Resources and Records. Is this using some clear naming for users?
Jose García
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
2015-02-11 14:11 GMT+01:00 Jose Garcia <jose.garcia@anonymised.com>:
Hi
1. At the top are displayed in a bar graphic several years, but no
size.
For the graphics, this was more an experiment that I'm about to drop as
facet on year is much easier to use.
Francois
2. There's 2 date sections below:
- *Resources created at*, this queries the createDate lucene field,
- *Records created at*, this queries the changeDate lucene field. The
label doesn't seem very clear.
Jose García
*GeoCat Bridge for ArcGIS allows instant publishing of data and metadata
<http://geocat.net/> for details. _________________________Jose
GarcíaGeoCat bvVeenderweg 136721 WD BennekomThe
Netherlandshttp://GeoCat.net/>*
Dive into the World of Parallel Programming. The Go Parallel Website,
sponsored by Intel and developed in partnership with Slashdot Media, is
your
hub for all things parallel software development, from weekly thought
leadership blogs to news, videos, case studies, tutorials and more. Take a
look and join the conversation now. http://goparallel.sourceforge.net/
GeoNetwork-devel mailing list
Hi Francois
Thanks for the feedback.
What do you think about the 2on point? The texts displayed for the other date filters is something that was agreed in the codesprint last month?
Jose García
On Wed, Feb 11, 2015 at 2:28 PM, Francois Prunayre <fx.prunayre@anonymised.com> wrote:
Hi
For the graphics, this was more an experiment that I’m about to drop as facet on year is much easier to use.
Francois
Jose García
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
sponsored by Intel and developed in partnership with Slashdot Media, is your
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
2015-02-11 14:32 GMT+01:00 Jose Garcia <jose.garcia@anonymised.com>:
Hi Francois
We did not discuss much the advanced search form which probably needs more
work (or to be dropped entirely ?), but "resources" and "records" sounds
clear to me... but maybe other label could be used. Any suggestions ?
"metadata" instead of "records" ?
Francois
Jose García
Hi
size.
Francois
Jose García
your
a
Hi
If for you is clear the difference, sounds fine.
The only stuff would be to change the label a bit to indicate changed instead of created for the records section. Records modified or similar label.
Jose García
On Wed, Feb 11, 2015 at 2:37 PM, Francois Prunayre <fx.prunayre@anonymised.com> wrote:
Hi Francois
We did not discuss much the advanced search form which probably needs more work (or to be dropped entirely ?), but “resources” and “records” sounds clear to me… but maybe other label could be used. Any suggestions ? “metadata” instead of “records” ?
Francois
Jose García
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Hi
Francois
Jose García
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
