[GeoNetwork-devel] GeoNetwork backup and restore procedure
I need some advice about backup and restore procedure for GeoNetwork.
I saw that backup page in official guide is blank.
thanks
Federico
Hi Federico
You need to backup the database, check the related documentation to the database you use and the data directory. You can find documentation about the data directory in http://geonetwork-opensource.org/manuals/trunk/eng/users/maintainer-guide/installing/customizing-data-directory.html?highlight=data%20directory
By default it’s stored in geonetwork/WEB-INF/data, but is recommended to configure to an external folder. Possibly a configuration like this is the best (from http://geonetwork-opensource.org/manuals/trunk/eng/users/maintainer-guide/installing/customizing-data-directory.html?highlight=data%20directory#advanced-data-directory-configuration):
-Dgeonetwork.dir=/data/catalogue
-Dgeonetwork.schema.dir=/app/tomcat/webapps/geonetwork/WEB-INF/data/config/schema_plugins
Use your custom paths. But this way, all the data directory is moved to a custom folder, while the metadata schemas are taken from the deployment, that is usually what you’ll want when upgrading to newer versions. The exception to this can be if you have custom changes in the metadata schemas.
If you have any customisation to the web UI, you’ll need to backup also.
Jose García
On Wed, Nov 23, 2016 at 12:38 PM, Federico Montinaro <federico.montinaro@anonymised.com> wrote:
thanks
Federico
GeoNetwork-devel mailing list
GeoNetwork-devel@…537…sourceforge.net
Vriendelijke groeten / Kind regards,
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
T: +31 (0)318 416664
Please consider the environment before printing this email.
HI Jose!
Thank you Jose,
2016-11-23 14:03 GMT+02:00 Jose Garcia <jose.garcia@anonymised.com>:
Hi Federico
Jose García
thanks
Federico
GeoNetwork-devel@anonymised.comorge.net
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
Federico Montinaro
+39 329 432 4062 | federico.montinaro@anonymised.com
Hi Jose,
it’s almost clear now
Thank you
Hi Federico
Jose García
thanks
Federico
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
Federico Montinaro
