Bugs item #1558489, was opened at 2006-09-14 03:11
Message generated for change (Tracker Item Submitted) made by Item Submitter
You can respond by visiting:
https://sourceforge.net/tracker/?func=detail&atid=533368&aid=1558489&group_id=72096
Please note that this message will contain a full copy of the comment thread,
including the initial issue submission, for this request,
not just the latest update.
Category: Other functionality
Group: v2.1.0
Status: Open
Resolution: None
Priority: 5
Submitted By: Nobody/Anonymous (nobody)
Assigned to: Nobody/Anonymous (nobody)
Summary: schema mistackes 19115 + Cor. 19115
Initial Comment:
I notice some mistakes in the actual schema GN in
regard with the 19115 standards and the corrigendum 19115.
mdLang/languageCode --> The domain of the content of
the ""language"" element is ISO 639-2. "-2"
specifies the three letter abbreviation used for
different countries. "-1"
specifies the two letter abbreviation. Therefore, the
pick list for the ""language"" element should contain
three letter values like ""eng"" for ""English"" not
two letter values like ""en"". Use the list from
http://www.loc.gov/standards/iso639-2/langhome.html
gmd:dataSetURI --> miss in GN
distInfo --> miss the link with distributionFormat
(distInfo/distorFormat)
spatRepInfo/Georect/numDims --> Type Integer (actual
string)
spatRepInfo/Georect/chkPtAv --> Type Booleen (actual
string)
spatRepInfo/Georect/chkPtAv/orieParaAv --> Type Booleen
(actual string)
spatRepInfo/Georect/chkPtAv -->Type Booleen (actual string)
string)
spatRepInfo/GridSpatRep/tranParaAv --> Type Booleen
(actual string)
dataExt/geoEle/BoundPoly/exTypeCode --> Type Booleen
(actual string)
dqReport/DQElementTypes/measResult/ConResult/conPass
--> Type Booleen (actual string)
contInfo/ImgDesc/lensDistInAv --> Type Booleen (actual
string)
contInfo/ImgDesc/filmDistInAv --> Type Booleen (actual
string)
contInfo/ImgDesc/camCalInAv --> Type Booleen (actual
string)
contInfo/ImgDesc/radCalDatAv --> Type Booleen (actual
string)
contInfo/ImgDesc/trianInd --> Type Booleen (actual string)
contInfo/FetCatDesc/incWithDS --> Type Booleen (actual
string)
contInfo/FetCatDesc/compCode --> Type Booleen (actual
string)
dataIdInfo/dataExt/vertEle --> [Corrigendum
19115]Delete vertUoM. Change the name vertDatum to vertCRS
refSysInfo/MdCoRefSys --> [Corrigendum 19115]to delete
gmd:locale [Corrigendum 19115]to implement in GN.
Implementation use to explain ?
geoBox/westBL + eastBL + southBL + northBL -->
[Corrigendum 19115]change type xs:string to xs:decimal.
Pierre.
