Feature Requests item #1554632, was opened at 2006-09-08 09:50
Message generated for change (Tracker Item Submitted) made by Item Submitter
You can respond by visiting:
https://sourceforge.net/tracker/?func=detail&atid=533371&aid=1554632&group_id=72096
Please note that this message will contain a full copy of the comment thread,
including the initial issue submission, for this request,
not just the latest update.
Category: Metadata standard
Group: None
Status: Open
Priority: 5
Submitted By: Tim Jacobs (tim_jacobs)
Assigned to: Nobody/Anonymous (nobody)
Summary: ISO 19115 Aggregate / series
Initial Comment:
In ISO 19115, there is a possibility to aggregate
multiple datasets (maps) into a larger data product.
Such aggregates are also referred to as "series" of
maps, and can be aggregated for different reasons
(initiatives/associationTypes).
When editing the XML Metadata (using the ISO 19115
grid template), HierarchyLevel does indicate that you
can create metadata for the "series" level (rather
than the "map" level). However, when doing so, there
is no possibility to specify the series, nor the maps
that it aggregates.
So, my question is: are there any plans to support the
aggregation of series of datasets, as foreseen in ISO
19115?
