[GeoNetwork-devel] [GeoNetwork opensource Developer website] #1015: GN + ANZMEST - xml_iso19139.mcpTooai_dc and xml_iso19139.mcpTorif_cs services not working
Reporter: awalsh | Owner: geonetwork-devel@…
     Type: defect | Status: new
Priority: major | Milestone: v2.8.0 RC0
Component: General | Version: v2.8.0RC0
Keywords: XML services, xml_iso19139.mcpTooai_dc, xml_iso19139.mcpTorif_cs |
Testing master-core GN from GIT commit 0a31ef.. (27/7/12, J. Garcia) +
ANZMEST plugin SVN 9272. Environment Windows XP, Jetty with
postgres/postgis GN db.
Clicking XML save-as icon on iso19139.mcp-1.4 schema metadata record xml
for services 'xml_iso19139.mcpTooai_dc', 'xml_iso19139.mcpTorif_cs'
returns 'Service not found'. Need these functions to properly save
iso19139-mcp records oai_dc or rif_cs XML
(BTW for iso19139-ANZLIC schema records the XML service
'xml_iso19139Tooai_dc' works OK)
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1015&gt;
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/&gt;
      Type: defect | Status: closed
Resolution: worksforme | Keywords: XML services, xml_iso19139.mcpTooai_dc, xml_iso19139.mcpTorif_cs
Changes (by simonp):
  * status: new => closed
  * resolution: => worksforme
Comment:
Andrew - you need to configure the services xml_iso19139mcpTooai_dc etc
manually as per the way it is done in the ANZMEST release (see WEB-INF
/config-metadata-schemaplugins.xml - this must be included in WEB-
INF/config.xml - done via config override in ANZMEST) as at the moment you
cannot add services to GN as part of a schema plugin.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1015#comment:1&gt;
Comment(by awalsh):
Simon,
Thanks! that is an important configuration step that I was missing i.e
add <include>config-metadata-schemaplugins.xml</include> to WEB-
INF/config.xml.
Perhaps this is something to document in the ANZMEST installation
instructions
and also in the GN Developers manual section on the Schema Plugins.
Andrew
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1015#comment:2&gt;
