#1051: Lucene searches for two keywords separated by dash return no result
Reporter: vsinceac | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: minor | Milestone: v2.6.4
Component: General | Version: v2.6.4
Keywords: Lucene, keywords, dash |
Found this for GN 2.6.4, I did not try other releases.
Example found on the fao geonetwork (also 2.6.4):
[http://www.fao.org/geonetwork/srv/en/main.home\]
There is one metadata containing "WOFOST-based" in Abstract. Here below
some simple searches by keywords (with or wihtout "", as result is the
same) for region=any, and the corresponding result:
"WOFOST based" -> OK (1)
"WOFOST-based" -> NOK (0)
"WOFOST?based" -> NOK (0)
"WOFOST*based" -> NOK (0)
"WOFOST/based" -> OK (1)
"WOFOST - based" -> OK (1)
"WOFOST ?based" -> NOK (0)
"WOFOST? based" -> NOK (0)
Is this the expected behavior? Should I clean the keywords list for "-"
(and other chars?) before sending the get query?
On the same geonetwork, both searches "November 2003 - June 2004" and
"November 2003 June 2004" return the same results (containing "November
2003 - June 2004" in Abstract).
Victor
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1051>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
