[GeoNetwork-devel] [GeoNetwork opensource Developer website] #107: could not perform search, create new metadata, upload thumbnail in ipv6 network
network
Reporter: wlx | Owner: geonetwork-devel@lists.sourceforge.net
     Type: defect | Status: new
Priority: major | Milestone:
Component: General | Version: v2.2.0 Final
Keywords: ipv6 |
Geonetwork version is 2.2.0.
The server and the client both have ipv6 address. When the client visit
the geonetwork server, these functions could not perform: search, create
new metadata, upload thumbnail.
In the log file:
2009-05-14 11:14:58,155 INFO [jeeves.webapp.main.home] - Creating default
search data
2009-05-14 11:14:58,156 INFO [jeeves.webapp.main.home] - Returning search
data
2009-05-14 11:14:58,206 ERROR [jeeves.service] - Exception executing gui
service : java.lang.NumberFormatException: For input string:
"2001:cc0:f006:0:221:9bff:fe6c:7168"
2009-05-14 11:14:58,207 ERROR [jeeves.service] - (C) Stack trace is :
         at
java.lang.NumberFormatException.forInputString(NumberFormatException.java:48)
         at java.lang.Integer.parseInt(Integer.java:456)
         at java.lang.Integer.parseInt(Integer.java:497)
         at
org.fao.geonet.kernel.AccessManager.getAddress(AccessManager.java:341)
         at
org.fao.geonet.kernel.AccessManager.isIntranet(AccessManager.java:327)
         at
org.fao.geonet.kernel.AccessManager.getUserGroups(AccessManager.java:170)
         at
org.fao.geonet.guiservices.metadata.GetLatestUpdated.exec(GetLatestUpdated.java:80)
         at jeeves.server.dispatchers.guiservices.Call.exec(Call.java:75)
         at
jeeves.server.dispatchers.AbstractPage.invokeGuiService(AbstractPage.java:119)
         at
jeeves.server.dispatchers.AbstractPage.invokeGuiServices(AbstractPage.java:104)
         at
jeeves.server.dispatchers.ServiceManager.dispatchOutput(ServiceManager.java:588)
         at
jeeves.server.dispatchers.ServiceManager.dispatch(ServiceManager.java:382)
         at jeeves.server.JeevesEngine.dispatch(JeevesEngine.java:616)
         at
jeeves.server.sources.http.JeevesServlet.execute(JeevesServlet.java:163)
         at
jeeves.server.sources.http.JeevesServlet.doGet(JeevesServlet.java:88)
         at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
         at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
         at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
         at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
         at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
         at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
         at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
         at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
         at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
         at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:286)
         at
org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:845)
         at
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583)
         at
org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
         at java.lang.Thread.run(Thread.java:619)
So, to use these functions, I make a temp solution:
wlx@...553...:~/Projects/geonetwork-2.2.0/src/org/fao/geonet/kernel$ svn diff
Index: AccessManager.java
--- AccessManager.java (版本 3883)
+++ AccessManager.java (工作副本)
@@ -322,11 +322,13 @@
                 String network =
settMan.getValue("system/intranet/network");
                 String netmask =
settMan.getValue("system/intranet/netmask");
- long lIntranetNet = getAddress(network);
- long lIntranetMask = getAddress(netmask);
- long lAddress = getAddress(ip);
+ // to avoid ipv6 problem
+ //long lIntranetNet = getAddress(network);
+ //long lIntranetMask = getAddress(netmask);
+ //long lAddress = getAddress(ip);
- return (lAddress & lIntranetMask) == lIntranetNet ;
+ //return (lAddress & lIntranetMask) == lIntranetNet ;
+ return false;
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/107&gt;
GeoNetwork opensource Developer website <http://trac.osgeo.org/geonetwork&gt;
