#1128: Changing protocol for online resources does not work properly
Reporter: ianwallen | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: major | Milestone: v2.8.0
Component: User interface (web) | Version: v2.8.0RC2
Keywords: |
When data is already loaded in the online resouce and the name contains
data, attempting to change the protocol generates an error
A file may have been uploaded. You cannot change the protocol until you
remove that file
This error does not make sense for most of the protocols.
Since this particular error message only seem to apply to "File for
download" option the code should be updated so that only when this option
is changed should it generate the error message.
Otherwise the current hack is to
* null the name
* change the protocol
* re-insert the name
More information can be found on this discussion [http://osgeo-
org.1560.n6.nabble.com/issues-with-changing-protocol-for-online-resources-
td5011580.html]
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1128>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
