#1147: unable to delete a file attached to a metadata
Reporter: landry | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: major | Milestone: v2.8.0
Component: General | Version: v2.8.0RC0
Keywords: |
We heavily use files attached to metadata in our geonetwork 2.8.0rc0
instance. Attaching a file works fine, but removing it through the
'delete' button next to thefile name is impossible, the operation fails
with a 'ServiceNotAllowedEx : Service not allowed' exception popup.
The workaround we've found so far is to remove the whole
<gmd:CI_OnlineResource> subtree (which as a sidenote doesnt delete the
file from the metadata_data directory on the server) , and reupload the
file with a different name.
Interesting thing, after uploading a file, there's a resources.get call
made with an empty fname, leading to a backtrace in the log. Related ?
Attaching geonetwork logs for file upload and removal try.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1147>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
Keywords: |
Comment(by ianwallen):
Worked for me on latest nightly build.
There have been a lot of updates since 2.8.0RC0 - may want to try the
current nightly build to see if the issue exists.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1147#comment:1>
Keywords: |
Comment(by landry):
Forgot to say this was with the widgets/extjs gui, if that can matter.
I'll retry with a fresh build from 2.8.x branch.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1147#comment:2>
Type: defect | Status: closed
Resolution: worksforme | Keywords:
Changes (by landry):
* status: new => closed
* resolution: => worksforme
Comment:
Right, after pulling from the 2.8.x branch and rebuilding,
resources.del.new correctly removes the file from the datadir, and unhooks
it from the xml.
There's still a GET /geonetwork-
private/srv/fre/resources.get?id=253&fname=&access=public
without fname set that triggers a 500 code and a BadParameterEx exception,
but i suppose that's not a big deal. closing the ticket.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1147#comment:3>
Type: defect | Status: reopened
Resolution: | Keywords:
* status: closed => reopened
* resolution: worksforme =>
Comment:
I've been able to reproduce the issue with 2.8.0rc2 - will try to go
deeper to find the root cause and the exact steps to reproduce.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1147#comment:4>
