#1198: Harvester / SQL error if user #1 removed
Reporter: fxp | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: blocker | Milestone: v2.9.0
Component: General | Version: v2.8.0RC2
Keywords: |
When running harvester user with id 1 is the owner of all records.
Removing this user makes all harvesting task failing.
2013-01-11 14:05:49,277 WARN [geonetwork.harvester] - - Failed to load
layer metadata : ERROR: insert or update on table "metadata" violates
foreign key constraint "metadata_own
er_fkey"
Detail: Key (owner)=(1) is not present in table "users".
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1198>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
