[GeoNetwork-devel] [GeoNetwork opensource Developer website] #1258: Helthcheck using wrong query for database healthcheck
Reporter: ianwallen | Owner: geonetwork-devel@…
     Type: defect | Status: new
Priority: major | Milestone: v2.8.1
Component: General | Version: v2.8.0
Keywords: |
As pointed out by Montse in http://osgeo-org.1560.n6.nabble.com/Oracle-
Database-health-check-issues-td5044740.html
DatabaseHealthCheck.java is using query "SELECT id from Metadata LIMIT 1"
which is not compatible with other databases.
As this is a simple check to see if the database is responding, I believe
it should be using the query that was identified in the config.xml
"validationQuery" as this query should be compatible with the database.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1258&gt;
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/&gt;
#1258: Healthcheck using wrong query for database healthcheck
Keywords: |
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1258#comment:1&gt;
Keywords: |
Comment(by drh):
My sense is that the validationQuery is to test the JDBC connection, but
the DatabaseHealthCheck should be a query (queries) aimed at checking the
status of the database as well as the connection. In 2.8.0, the
DatabaseHealthCheck fails on Oracle:
* Csw GetCapabilities: OK
* Csw GetRecords: OK
! Database Connection: ERROR
! ORA-00933: SQL command not properly ended
java.sql.SQLSyntaxErrorException: ORA-00933: SQL command not properly
ended
         at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:440)
         at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:396)
         at oracle.jdbc.driver.T4C8Oall.processError(T4C8Oall.java:837)
         at oracle.jdbc.driver.T4CTTIfun.receive(T4CTTIfun.java:445)
         at oracle.jdbc.driver.T4CTTIfun.doRPC(T4CTTIfun.java:191)
         at oracle.jdbc.driver.T4C8Oall.doOALL(T4C8Oall.java:523)
         at
oracle.jdbc.driver.T4CPreparedStatement.doOall8(T4CPreparedStatement.java:207)
         at
oracle.jdbc.driver.T4CPreparedStatement.executeForDescribe(T4CPreparedStatement.java:863)
         at
oracle.jdbc.driver.OracleStatement.executeMaybeDescribe(OracleStatement.java:1153)
         at
oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1275)
         at
oracle.jdbc.driver.OraclePreparedStatement.executeInternal(OraclePreparedStatement.java:3576)
         at
oracle.jdbc.driver.OraclePreparedStatement.executeQuery(OraclePreparedStatement.java:3620)
         at
oracle.jdbc.driver.OraclePreparedStatementWrapper.executeQuery(OraclePreparedStatementWrapper.java:1491)
         at
org.apache.commons.dbcp.DelegatingPreparedStatement.executeQuery(DelegatingPreparedStatement.java:96)
         at
         at jeeves.resources.dbms.Dbms.selectFull(Dbms.java:213)
         at jeeves.resources.dbms.Dbms.select(Dbms.java:176)
         at
org.fao.geonet.monitor.health.DatabaseHealthCheck$1.check(DatabaseHealthCheck.java:25)
         at
com.yammer.metrics.core.HealthCheck.execute(HealthCheck.java:165)
         at
com.yammer.metrics.core.HealthCheckRegistry.runHealthChecks(HealthCheckRegistry.java:53)
         at
com.yammer.metrics.reporting.HealthCheckServlet.doGet(HealthCheckServlet.java:61)
         at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
         at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
         at
com.yammer.metrics.reporting.AdminServlet.doGet(AdminServlet.java:103)
         at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
         at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
         at
org.fao.geonet.monitor.webapp.WebappMetricsFilter.doFilter(WebappMetricsFilter.java:96)
         at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
         at
         at
org.tuckey.web.filters.urlrewrite.RuleChain.handleRewrite(RuleChain.java:176)
         at
org.tuckey.web.filters.urlrewrite.RuleChain.doRules(RuleChain.java:145)
         at
org.tuckey.web.filters.urlrewrite.UrlRewriter.processRequest(UrlRewriter.java:92)
         at
org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:381)
         at
         at
         at
org.fao.geonet.monitor.MonitorSecurityFilter.doFilter(MonitorSecurityFilter.java:51)
         at
         at
         at
org.fao.geonet.monitor.webapp.MetricsRegistryInitializerFilter.doFilter(MetricsRegistryInitializerFilter.java:31)
         at
         at
         at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
         at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
         at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
         at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
         at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
         at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298)
         at
org.apache.jk.server.JkCoyoteHandler.invoke(JkCoyoteHandler.java:190)
         at
org.apache.jk.common.HandlerRequest.invoke(HandlerRequest.java:291)
         at
org.apache.jk.common.ChannelSocket.invoke(ChannelSocket.java:769)
         at
org.apache.jk.common.ChannelSocket.processConnection(ChannelSocket.java:698)
         at
org.apache.jk.common.ChannelSocket$SocketConnection.runIt(ChannelSocket.java:891)
         at
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:690)
         at java.lang.Thread.run(Thread.java:662)
* Lucene Index: OK
* Metadata Index Errors: OK
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1258#comment:2&gt;
