#1261: Schema plugin / SeaDataNet CDI metadata profile
Reporter: fxp | Owner: geonetwork-devel@…
Type: task | Status: new
Priority: major | Milestone:
Component: General | Version:
Keywords: IFREMER |
== !SeaDataNet CDI metadata profile ==
The aim is to produce a pluggable profile for SDN-CDI metadata profile
which is an extension of ISO19139. The plugin will be supported by
!GeoNetwork 2.9 or above.
* Cf : http://www.seadatanet.org/Data-Access/Common-Data-Index-CDI
* Cf : http://www.seadatanet.org/Standards-Software/Metadata-formats
This new profile is identified as iso19139.sdn-cdi.
Schema detection is based on the presence of the following element in a
record:
<gmd:metadataStandardName>
<gco:CharacterString>ISO 19115/SeaDataNet
profile</gco:CharacterString>
</gmd:metadataStandardName>
If this fragment is found, the record is attached to the iso19139.sdn-cdi
profile (if deployed in the catalogue instance).
Labels from the schema specification are used to make a localization file
for the English language for all element from the SDN namespace.
Some elements of the CDI require integration with indexing and view/edit
features.
Task:
* create CDI SDN profile
* publish the profile in GeoNetwork schema repository on Github
(https://github.com/geonetwork/schema-plugins)
=== Keywords ===
gmd:keywords may contains :
<gmd:keyword>
<sdn:SDN_ParameterDiscoveryCode codeSpace="SeaDataNet"
codeListValue="ATVS"
codeList="http://vocab.nerc.ac.uk/isoCodelists/sdnCodelists/cdicsrCodeList.xml#SDN_ParameterDiscoveryCode">Atmospheric
visibility and transparency</sdn:SDN_ParameterDiscoveryCode>
or
<sdn:SDN_PlatformCategoryCode...
or
<sdn:SDN_EDMERPCode...
</gmd:keyword>
Tasks:
* Indexing: Those elements will be indexed as keywords.
* Editing: They will not be fully supported in edit mode (ie. the element
attribute will not be editable)
=== Point and curve in bounding polygon ===
Spatial indexing: Curve or point will not be supported in the shapefile
index due to a mix of geometry.
In editing mode the geometry will be displayed but could not be edited.
Tasks:
* Check that it does not break indexing of the record
=== isoType attribute ===
SDN CDI record use
<sdn:SDN_DataIdentification gco:isoType="MD_DataIdentification_Type">
GeoNetwork support
<sdn:SDN_DataIdentification gco:isoType="gco:MD_DataIdentification">
Task:
* Add support for both case in iso19139 schema in GeoNetwork.
=== Schematron validation ===
No schematron is made for custom profile rules.
Example: metadata identifier "Free text -> urn as defined in RFC 1737 and
starting with the string “urn:SDN:CDI:“
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1261>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
