#1281: Indexing / geometry / avoid multicurve GML feature
Reporter: fxp | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: minor | Milestone: v2.11.0
Component: General | Version: v2.11.0
Keywords: |
When extracting bounding "polygon", we may end up trying to convert
MultiCurve to Polygon which trigger errors and record is not indexed. Do
not support MultiCurve in indexing (we can't mix geometries in shapefile
BTW)
<!-- MIKADO AUTOMATIC var63=[-76.816333 ... -57.079131] (Curves-
coordinates) MULTIPLE / OPTIONAL -->
<gml:posList>-76.816333 -36.777203 -77.192141 -43.722611 -80.198605
-47.195299 -78.319565 -50.400867 -74.561741 -54.674947 -70.052045
-57.079131</gml:posList>
</gml:LineString>
</gml:curveMember>
</gml:MultiCurve>
class com.vividsolutions.jts.geom.MultiLineString cannot be
converted to a polygon. Check Metadata
java.lang.IllegalArgumentException: class
com.vividsolutions.jts.geom.MultiLineString cannot be converted to a
at
org.fao.geonet.kernel.search.spatial.SpatialIndexWriter.toMultiPolygon(SpatialIndexWriter.java:453)
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/1281>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
