#161: selection manager set iterators not synchronized, can fail with
ConcurrentModificationException
Reporter: simonp | Owner: geonetwork-devel@lists.sourceforge.net
Type: defect | Status: new
Priority: major | Milestone: v2.4.1
Component: General | Version: v2.5.0
Keywords: |
Reported by James.Q.Wilson@...275...:
I'm discovering more concurrency errors under load in geonetworks. BTW -
thanks for CSW fix for error I reported earlier in week.
The errors are for geonetworks 2_4_1 in Tomcat 6.20 with 1000 iso records
loaded:
- Massive Delete fails with java.util.ConcurrentModificationException -
see stack trace below. This results in inconsistency between lucene index
and database. Lucene index drops records up to point at which exception
occurs. Since commit is never done in database, data still exists, and can
be recovered by rebuilding lucene index.
- MassiveUpdatePriviledges fails with
java.util.ConcurrentModificationException - see stack trace below
- MassiveUpdateCategories - got no stack trace recorded for this one.
Problem seems to be with HashSet declared in SelectionManager. These are
wrapped as synchronizedSet, which requires all iterators to be in
synchronized blocks (according to Java doc).
Iterators over this map in MassiveDelete / etc are not synchronized.
Explicitly synchronizing the iterators when these sets are accessed seems
to fix the concurrency problems:
eg
synchronized(sm.getSelection("metadata")) {
// use iterator here
Regards
James
Stack traces:
First the massive delete:
88562 [34658350@...604...] ERROR jeeves.service - Exception when executing
servic
e
788562 [34658350@...604...] ERROR jeeves.service - (C) Exc :
788562 [34658350@...604...] DEBUG jeeves.service - Raised exception while
executin
g service
<error id="error">
<message />
<class>ConcurrentModificationException</class>
<stack>
<at class="java.util.HashMap$HashIterator" file="HashMap.java"
line="921" me
thod="nextEntry" />
<at class="java.util.HashMap$KeyIterator" file="HashMap.java"
line="956" met
hod="next" />
<at class="org.fao.geonet.services.metadata.MassiveDelete"
file="MassiveDele
te.java" line="87" method="exec" />
<at class="jeeves.server.dispatchers.ServiceInfo"
file="ServiceInfo.java" li
ne="238" method="execService" />
ne="141" method="execServices" />
<at class="jeeves.server.dispatchers.ServiceManager"
file="ServiceManager.ja
va" line="377" method="dispatch" />
<at class="jeeves.server.JeevesEngine" file="JeevesEngine.java"
line="621" m
ethod="dispatch" />
<at class="jeeves.server.sources.http.JeevesServlet"
file="JeevesServlet.jav
a" line="174" method="execute" />
a" line="89" method="doGet" />
<at class="javax.servlet.http.HttpServlet" file="HttpServlet.java"
line="707
" method="service" />
</stack>
<request>
<language>en</language>
<service>metadata.massive.delete</service>
</request>
</error>
Then the massive Privs:
1454281 [http-8080-3] ERROR jeeves.service - Exception when executing
service
1454281 [http-8080-3] ERROR jeeves.service - (C) Exc :
ificationException
at java.util.HashMap$HashIterator.nextEntry(HashMap.java:921)
at java.util.HashMap$KeyIterator.next(HashMap.java:956)
at
org.fao.geonet.services.metadata.MassiveUpdatePrivileges.exec(Massive
UpdatePrivileges.java:85)
at
jeeves.server.dispatchers.ServiceInfo.execService(ServiceInfo.java:24
4)
at
jeeves.server.dispatchers.ServiceInfo.execServices(ServiceInfo.java:1
41)
at
jeeves.server.dispatchers.ServiceManager.dispatch(ServiceManager.java
:377)
at jeeves.server.JeevesEngine.dispatch(JeevesEngine.java:621)
at
jeeves.server.sources.http.JeevesServlet.execute(JeevesServlet.java:1
74)
at
jeeves.server.sources.http.JeevesServlet.doGet(JeevesServlet.java:89)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(Appl
icationFilterChain.java:290)
at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationF
ilterChain.java:206)
at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperV
alve.java:233)
at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextV
alve.java:191)
at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.j
ava:128)
at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.j
ava:102)
at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineVal
ve.java:109)
at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.jav
a:293)
at
org.apache.coyote.http11.Http11Processor.process(Http11Processor.java
:849)
at
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.proce
ss(Http11Protocol.java:583)
at
org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:45
4)
at java.lang.Thread.run(Thread.java:619)
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/161>
GeoNetwork opensource Developer website <http://trac.osgeo.org/geonetwork>
