[GeoNetwork-devel] [GeoNetwork opensource Developer website] #170: Metadata record gets overwritten by another one
Reporter: stegherr | Owner: geonetwork-devel@lists.sourceforge.net
     Type: defect | Status: new
Priority: minor | Milestone:
Component: General | Version: v2.4.1
Keywords: metadata editor |
Using Mozilla Firefox version 3.5.5 this happened as a user wanted to keep
open two metadata records at the same time to compare them and transfer
data.
To reproduce the bug:
    1. Create a new metadata record (Administration -> New metadata). Make
sure you are using the "Default view". Fill in a few parameters and use as
a title "Data filled in". Click on Save and close.
    1. Create a second metadata record in the same way (no need to fill in
any parameters). Use the title "Data empty".
    1. Open another Firefox window:
     * In the first window open the record called "Data filled in", select
edit and go to Advanced view,
     * In the second window open the record called "Data empty", select
edit and go to Advanced view too,
    1. Then on the "Data empty" record, go to the Identification tab and do
the same for the other record,
    1. Leave both records by pressing the Cancel button and close one
window again,
    1. Both metadata records are identical now.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/170&gt;
GeoNetwork opensource Developer website <http://trac.osgeo.org/geonetwork&gt;
