#277: Exported Zip file anomoly
Reporter: osjonathan | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: trivial | Milestone: v2.6.0 RC2
Component: General | Version: v2.6.0RC1
Keywords: |
I exported a metadata template as a zip file.
The resulting zip-file has an anomaly which may be as a result of the way
its created or it may be a Windows thing.
Attached is a screenshot of the root-directory of the zip. The top-left
window is using Window's own zip utility, and the bottom right is 7zip.
As you can see, for some reason windows thinks there's a empty file in the
directory with the same name as the folder with the metadata. When I
extract the .zip, the 0 byte file doesn't get created.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/277>
GeoNetwork opensource Developer website <http://trac.osgeo.org/geonetwork>
Priority: trivial | Milestone: v2.7.0
Keywords: |
Changes (by Fxp):
* milestone: v2.6.0 RC2 => v2.7.0
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/277#comment:1>
Type: defect | Status: closed
Resolution: wontfix | Keywords:
Changes (by Fxp):
* status: new => closed
* resolution: => wontfix
Comment:
IRC meeting discussion : 277 is an issue when we open the zip file with
windwos utility. so maybe our way to create the zip file is not the best
one for windows utility but as long as the empty file is not created
extracting the zip, it's not an issue
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/277#comment:2>
