#421: INSPIRE option for search form and CSW
Reporter: fxp | Owner: geonetwork-devel@…
Priority: minor | Milestone: v2.7.0
Component: General | Version: v2.6.2
Keywords: |
It could be nice to separate the INSPIRE search form option from the
INSPIRE CSW end-point. Some people may be interested to activate INSPIREd
CSW and not having the complexe INSPIRE search form.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/421>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
Keywords: |
Comment(by josegar74):
The patch allows to configure in System administration gui:
* Enable INSPIRE (CSW end-point and indexing of metadata INSPIRE fields)
* Enable INSPIRE search form (if previous option is enabled)
* Configure enabled optional metadata views (Simple, ISO, INSPIRE, XML)
and default metadata view
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/421#comment:1>
Type: enhancement | Status: closed
Resolution: fixed | Keywords:
Changes (by josegar74):
* status: new => closed
* resolution: => fixed
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/421#comment:2>
Changes (by fderuette):
* cc: fderuette (added)
Comment:
I just tested GéoSource 2.7.1, the possibility to configure the optional
metadata views is well.[[BR]]
[[BR]]
* But for the default metadata view :
[[BR]]
* I use the "essential view" (fra - perhaps it's only with the
ISO19139.fra ?) and in the 2.7.0 it was my default view and now I can't do
it
* my default view is all the time the INSPIRE one (I tried with the
Simple and the Advanced)
[[BR]]
* And for the INSPIRE search form, enabled or not, I have the same search
fields.
[[BR]]
FD
[[BR]]
Postscript: it's the first time that I use the trac OSGeo, I don't no if I
have to reopen the ticket in this case...
I wanted to change the version to the 2.7.1 but I can't...
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/421#comment:3>
Comment(by Fxp):
Replying to [comment:3 fderuette]:
> the possibility to configure the optional metadata views is well.[[BR]]
> [[BR]]
> [[BR]]
it
> [[BR]]
search fields.
!GeoSource use the widget UI. In the widget, the default layout in view
mode is the "custom simple" view (ie. http://www.neogeo-online.net/blog
/wp-content/uploads/2011/04/geonetwork-simple-view.png). And you can
configure the default layout for the edit mode in
app/search/js/Settings.js
GeoNetwork.Settings.editor = {
defaultViewMode : 'inspire'
The administration for the default view only alter legacy UI. The list of
views alter both UI.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/421#comment:4>
Comment(by fderuette):
If I understand the administration for the default view is not functional
for GeoSource ?[[BR]]
I configured the default layout for the edit mode in
apps/search/js/Setting.js and apps/apps/search/js/Setting.js with the
values :
defaultViewMode : 'fra'
The default editor view is still Inspire, I wasn't sure of the name of the
essential view, so I try for the advanced view :
defaultViewMode : 'advanced'
Still the same... no result.
[[BR]]
You didn't give an answer to the question that was about the Inspire
search form: the search fields are still the same with or without the
activated search form.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/421#comment:5>
Ok, the value have to be modified in Setting.js and App-mini.js.
To be able to use the tab, the value have to be "fraTabDesc" for the
essential view and "Identification" or the name of an other tab for the
advanced view.
I still don't know for the Inspire search form...
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/421#comment:6>
