[GeoNetwork-devel] [GeoNetwork opensource Developer website] #586: Geotools (with spatial db) and geonetwork database should use same pool and add flexible JNDI
add flexible JNDI
Reporter: simonp | Owner: geonetwork-devel@…
Priority: major | Milestone: v2.7.0
Component: General | Version:
Keywords: Geotools, database connections |
Currently GeoNetwork uses two database connection pools if using spatial
database. Also JNDI option assumes tomcat Apache Commons DBCP. This patch
adds a more flexible JNDI provider and uses one connection pool via
Geotools.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/586&gt;
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/&gt;
add flexible JNDI
      Type: enhancement | Status: closed
Resolution: fixed | Keywords: Geotools, database connections
Changes (by simonp):
  * status: new => closed
  * resolution: => fixed
Comment:
Fixed in svn rev 8223 - JNDIPool.java (with example of how to use in WEB-
INF/config.xml) allows geotools and geonetwork to use the same database
pool with config in the container. JNDIPool also allows use of either
shapefile or database for spatial index via provideDataStore config
element - this is useful because at the moment we only support postgis for
spatialindex but if you wanted to put the spatialindex in another database
(eg. Oracle) then you can now add your own spatialindex table and then
config GeoNetwork to use it.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/586#comment:1&gt;
