#708: Add document and field boosing at index time in Lucene configuration
Reporter: fxp | Owner: geonetwork-devel@…
Priority: major | Milestone: v2.7.0
Component: General | Version:
Keywords: |
* Default !GeoNetwork lucence configuration does not set any boosts (ie.
not changed)
* This feature has to be used by expert users to alter default search
behavior scoring according to catalogue content.
* Add configuration for boosting fields in lucene-config.xml. Some fields
are more important than others. This type of configuration will alter OR
queries behavior.
* Configuration: Example to promote title
<field name="title" boost="1.5F"/>
* Add configuration for boosting a document in lucene-config.xml.
* A use case could be: to promote series and not promote datasets part
of a series.
* A sample boosting class is added: !ImportantDocument.
* Boost factor for a document is computed based on document field and
value match.
* Example 1: the following configuration will
* Default boost is 1
* Add .1 to a document having type = series
* Remove .3 to a document having type = service
* Add .4 to a document having keyword = Elevation
<boostDocument
name="org.fao.geonet.kernel.search.function.ImportantDocument">
<Param name="fields" type="java.lang.String"
value="type,type,keyword"/>
<Param name="values" type="java.lang.String"
value="series,service,Elevation"/>
<Param name="boosts" type="java.lang.String" value=".1F,-.3F,.4F"/>
</boostDocument>
* Example 2: to promote series and not promote datasets part of a
series:
<boostDocument
<Param name="fields" type="java.lang.String" value="type,parentUuid"/>
<Param name="values" type="java.lang.String" value="series,NOTNULL"/>
<Param name="boosts" type="java.lang.String" value=".1F,-.3F"/>
</boostDocument>
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/708>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
